Hello guys, i’m trying to undervolt my new laptop using throttlestop but i’ve fivr options greyed because there is the undervolt protection.
I’m trying to disable it but i cannot find the CFG Lock Id inside the DXE_driver_setup IFR.
These are the values inside the file: 0xA2F2D One Of: Enable/Disable Overclocking Lock (BIT 20) in FLEX_RATIO(194) MSR , VarStoreInfo (VarOffset/VarName): 0x49, VarStore: 0x2, QuestionId: 0x1E7, Size: 1, Min: 0x0, Max 0x7, Step: 0x0 {05 91 B5 06 B6 06 E7 01 02 00 49 00 10 10 00 07 00}
0xA2F3E One Of Option: When set, will map IO_read instructions sent to IO registers PMG_IO_BASE_ADDRBASE+offset to MWAIT(offset), Value (8 bit): 0x0 (default) {09 07 B7 06 30 00 00}
0xA2F45 One Of Option: CFG Lock, Value (8 bit): 0x1 {09 07 B8 06 00 00 01}
0xA2F4C One Of Option: Configure MSR 0xE2[15], CFG Lock bit, Value (8 bit): 0x2 {09 07 B9 06 00 00 02}
0xA2F53 One Of Option: Interrupt Redirection Mode Selection, Value (8 bit): 0x7 {09 07 BA 06 00 00 07}.
As you can see there is only the overclocking lock id (0x49).
Could you help me to find also the cfg lock id?
