HWINFO is showing that my pc has RPAT enabled is there is any way to disable it since my machine doesnet support AMT
Asus support gave me no clear answer on this topic just said the my mb dosent support it and ended chat with me
I don’t consider HwInfo the most qualified tool regarding CSME capabilities. Maybe the meaning of the configuration bytes changed with ME versions and HwInfo might not translate absolutely correct according to version development.
