- Method same x4 3.0…
2. On slot 2 (x8) card runs fine at x8 3.0 (with nvme). I will try another cardon pcie 1 x16 slot.
Update:
I tried old gpu AMD Radeon RX 480 at slot 1. cmos clear+plug in than start but my mobo cant detect this gpu. (at slot 2 works good at 8x)
I tried 1 slot install AMD Radeon RX 480 and another 8x slot gtx 1080 and both work, but 1 slot running at x4 :/.
Probably i need to rma mobo
Yes, sounds like there may be some issue with slot #1 then. Did you try cleaning cards gold finger with alc, and blow out slot to make sure no dust in there causing issue?
yes, the first thing i tried was gpu and mobo gold contacts clean up with alc
