I’ve got a Z68 Extreme3 Gen3 running the second-to-newest ASRock BIOS (v2.30). I’m trying to switch to a larger primary HDD (from a Samsung EVO 500GB to a Crucial 4TB SSD) but of course that requires GPT partitions, which in turn requires UEFI booting, which means checking GPU compatibility… ugh! A maze of dependencies, and each one seems like a roll of the dice.
I’m holding off on going to v2.31A (beta) because of reports that the change is bad, but the patch notes do talk about supporting GOP VBIOS which seems important. It seems like there are a lot of low-level hardware and firmware experts here, so broadly speaking: what is my surest path to success here?
I have:
- Intel Core i7 3770 Ivy Bridge
- Gigabyte’s version of the NVIDIA RTX3060 12GB card running the 94.04.71.00.EE VBIOS (?) which CPU-Z informs me supports UEFI (I imagine all RTX 3000-series support this out of the box!)
- ASRock Z68 Extreme3 Gen3 with Chipset rev 09 and South Bridge rev B3
- BIOS v2.30 with Microcode 0x21
I guess my biggest question for you experts is do you foresee any risk to upgrading the BIOS given this hardware configuration?
Would also cheerfully take tips on the right order of operations to try the MBR-to-GPT upgrade. Upgrading the C-drive in place seems fraught because if it goes bad, I can’t easily go back! Cloning the C-drive to the new drive (I have a Sabrent drive cloning sled) seems like a no-brainer. I already tried using MiniTool to clone the drive and upgrade the boot sector(s) to GPT all at once, but when I do that, and select “EFI” instead of “Legacy” in the BIOS, the machine hangs at the BIOS splash screen and takes no keyboard input.
