Haplo
1
Hello all,
I have an old Asus P5VDC-MX MoBo with the BIOS corrupted. This the Winbond W39V040CPZ BIOS chip
Ihave and had used the CH34IA flasher, but I have searched a lot in the net, but I do not know how to flash such kind of chip.
Evidently I do not see how to do it with the CH34IA. There is any possibility to flas this winbond chip?
Thanks in advance
lfb6
2
W39V040CPZ is a parallel chip, most cheap CH341 are configured to SPI (serial).
TL866 has the chip on the compatibility list, flashrom does support it
http://www.autoelectric.cn/MiniPro/TL866II_List.txt
https://www.flashrom.org/Supported_hardware
Haplo
3
Thanks @lfb6 , I will try TL866. I did not know it
