i have https://ark.intel.com/products/94917/Int…-3_0-x4-3D1-TLC ssd and i want to use that disk as a systematic my question how to configure the system and whether it is possible to connect it to my board gigabite ga880 ga ud3h rev 3.1 and how. The question I need to do to be bootable and to install it on any windows7 or windows10.To summarize ssd is nvme and what needs to be done to be recognized by my board because I have seen forums that it is feasible on older boards with award bios and a system is built from them
@boketa979 :
Welcome to the Win-RAID Forum!
You will be able to get Win10 (best choice for your project) or Win7 (needs a suitable NVMe driver) installed onto the Intel 600p NVMe SSD, but you will not be able to boot directly off it, because your mainboard BIOS doesn’t contain the required NVMe EFI module and is not an AMI UEFI BIOS, where such module can be inserted.
So I recommend to read the first posts of the various guides, which are offfered within the “[HOW-TO’s] NVMe Support for old Systems” to find the best solution. As already mentioned above, >this< guide is not usable with your system.
If you have any questions about the guides and their different methods, please post them into the related thread.
Good luck!
Dieter (alias Fernando)
can this method https://audiocricket.com/2016/12/31/boot…t-se-mainboard/ to work on the amd platform specifically amd it 880 ga ud3h motherboard with https: //ark.intel.com/products/94917/Intel-SSD-600p-Series-128GB-M_2-80mm-PCIe-3_0-x4-3D1-TLC nvme ssd and whether it changes something in the procedure or is completely the same if I have a ray, I’d like to explain to you a bit bet
@boketa979 :
If you want to know, whether a certain method works for your system and NVMe SSD,you should ask the person, who has written the related guide.
