How to know exactly my intel ME SKU?
Hello :D!
I have to fix INTEL-SA00086 vulnerability in various computers. And then, I’m scripting python code which distinguish intel me SKU.
I think that ME Analyzer’s MEA.dat will help me because MEA.dat has many identifier of SKU.
But… I don’t know what to do.
Update all their BIOS, problem solved. Their flashing tool will identify the correct SKU when using the stock flashing app, and will update BIOS accordingly.
If you want to know, only way I know of is to try flashing BIOS with the correct or incorrect BIOS package and then check the logs, it will show “Success found xxx SKU” or “failed, SKU XX not match” stuff like that.
For python code and doing all this, I haven’t a clue, maybe plutomaniac can help, or can tag someone else in there can help.
