How To Mini Guides
I think it would be a good idea for a "How to Mini Guide" section where people can go for instant information on how to rectify various computer problems. for example here is one i made below: moderators please feel free to sticky.
Step by step 100MB bootable EFI partition restore procedure:
When an EFI partition is deleted, you can make your single/multi-boot Windows10 operating system bootable again by recreating a new one by using the Command Prompt. Skip step 1 if your second/other Windows10 operating system is bootable and functioning.
1. Boot your computer using the Windows 10 installation media or Windows 10 recovery disk. On the first screen, press SHIFT+F10 to enter the Command Prompt.
2. Run the commands below to shrink a partition for unallocated space:
diskpart
list disk
select disk # ( Select the disk where you want to add the EFI system partition)
list partition
select partition # (Select the main operating system partition which you want to shrink)
shrink desired=100 (Shrink the selected partition by 100MB.)
3. Run the following commands to create the EFI system partition with the unallocated space:
create partition efi size=100
format quick fs=fat32
assign letter=Z (You may replace “Z” with any other unused drive letter)
exit
4. Use the command below to copy the boot files from the currently running windows partition to the newly created EFI system partition and create the bootable BCD store in it:
bcdboot C:\windows /s Z: (“C” is the drive letter of the system partition and “Z” is the drive letter you want to assign to the newly created EFI partition.)
exit
5. Restart your computer then enter the UEFI to select a primary windows bootloader
I think this is a cool idea (but it’s up to the mods) I’ll post a guide later
@POE_UK
Thank you for having started this thread!
I agree with you: This Forum contains a lot of "HowTo Guides" and solutions for many PC/Mobile problems, but it is sometimes difficult for visitors and new members to find them (despite our very effective Forum "Search" box), especially when such tips/guides are hidden within very voluminous threads.
@Aquavision @all other interested Form members
If there should be a massive interest in a collection of not Storage Drivers/BIOS related tips and guides, please let us know it.
My idea is to create a new Sub-Forum named "PC Tips (not Storage Driver/BIOS related)", but this would require much more than 2 Forum members, who are able and willing to start the related threads.
I am curious about your feedback!
Thank you for your support! I will make a mini guide (of an idea I have)
Hint: windows XP on the Z390!?!?!
