Hidden Bios Menu’s example.
PBS menu is available
Without Use Of Universal Form Browser.
Or any other perquisite modifications.
Happy to share instructions if anyone would like to know how I made it.
Kind Regards, Smokeless.
Edit by Fernando: Thread title shortened and customized
Hello buddy. Good to see you on the forum again. Why logging in from the new profile? Decided to start life with a clean slate?
Would this remove the lock on the oc for cpu I wonder?
ryzen master integration do you mean
or bios related setting pointers actually working after runtime begins?
bro Did you resolve the vddio lock issue?
