Got this PC and on the screen have message that ME is under manufacturing mode.
Flashed latest BIOS 2.29 and latest ME Firmware 7.1.86.1221
And ideas how to switch off this mode ?
Intel(R) MEManuf Version: 7.1.50.1166
Copyright(C) 2005 - 2011, Intel Corporation. All rights reserved.
Platform stepping value is 4
FW Status Register1: 0x1E000255
FW Status Register2: 0x68000006
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: M0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
ICC: Valid OEM data, ICC programmed
Get FWU info command…done
Get FWU version command…done
Get FWU feature state command…done
Get ME FWU platform type command…done
Get ME FWU feature capability command…done
Feature enablement is 0x3A1C46
gFeatureAvailability value is 0x1
OEM ICC data valid and programmed correctly
Request Intel(R) ME test result command…done
vsccommn.bin was created on 04:35:50 08/08/2012 GMT
SPI Flash ID #1 ME VSCC value is 0x2005
SPI Flash ID #1 (ID: 0xC22017) ME VSCC value checked
SPI Flash ID #1 BIOS VSCC value is 0x2005
SPI Flash ID #1 (ID: 0xC22017) BIOS VSCC value checked
FPBA value is 0x0
No Intel Wireless device was found
Get Intel(R) ME test data command…done
Total of 23 Intel(R) ME test result retrieved
Micro Kernel - Blob Manager: Set - Passed
Micro Kernel - Blob Manager: Get - Passed
Micro Kernel - Blob Manager: Remove - Passed
Policy Kernel - SMBus: Read byte - Passed
Policy Kernel - ME Password: Valid MEBx password - Passed
Policy Kernel - Power Package: Package 1 supported - Passed
Policy Kernel - Power Package: Default package supported - Passed
Policy Kernel - ME Configuration: Wlan Power Well - Passed
Policy Kernel - ME Configuration: CPU Missing Logic - Passed
Policy Kernel - ME Configuration: M3 Power Rails Available - Passed
Policy Kernel - Embedded Controller: Get power source - Passed
Common Services - General: Low power idle timeout - Passed
Common Services - Provisioning: Valid MEBX password change policy - Passed
Common Services - Provisioning: Client Config mode is valid - Passed
Common Services - General: Vlan not enabled on mobile - Passed
Common Services - Provisioning: Both PID and PPS are set - Passed
Common Services - Provisioning: MEBX password set when PID and PPS set - Passed
Common Services - Wireless LAN: Connectivity to NIC - Skipped
AMT - Privacy Level: Valid Privacy Level settings - Passed
AMT - Power: Valid WLAN power well (Desktop) - Passed
AMT - Power: Power-package 2 supported - Passed
AMT - Hardware Inventory: BIOS tables - Passed
Policy Kernel - Power Package: Live Heap Test - Passed
Clear Intel(R) ME test data command…done
MEManuf Test Passed
Intel(R) MEInfo Version: 7.1.50.1166
PMXUtil: Error during PMX Call: PMxDrv!MAPPHYS - Bad Input Parameters
Intel(R) Manageability and Security Application code versions:
BIOS Version: Not available
MEBx Version: Not available
Gbe Version: 1.3
VendorID: 8086
PCH Version: 4
FW Version: 7.1.86.1221
UNS Version: Not Available
LMS Version: Not Available
MEI Driver Version: 11.0.0.1155
Wireless Hardware Version: Not Available
Wireless Driver Version: Not Available
FW Capabilities: 3808326
Intel(R) Standard Manageability - PRESENT/ENABLED
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Standard Manageability State: Enabled
CPU Upgrade State: Upgrade Capable
Cryptography Support: Enabled
Last ME reset reason: Power up
Local FWUpdate: Enabled
BIOS and GbE Config Lock: Enabled
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID #1: C22017
SPI Flash ID VSCC #1: 20052005
SPI Flash BIOS VSCC: 20052005
BIOS boot State: Post Boot
OEM Id: 00000000-0000-0000-0000-000000000000
Link Status: Link up
System UUID: 404e2800-9e12-11e2-0000-ffffffffffff
MAC Address: 00-11-85-74-f9-47
IPv4 Address: 0.0.0.0
IPv6 Enablement: Disabled
Privacy Level: Default
Configuration state: Not started
Provisioning Mode: PKI
Capability Licensing Service: Enabled
Capability Licensing Service Status: Permit info not available
OEM Tag: 0x00000001|addpics|4fm-2-aadf.jpg-invaddpicsinvv,4fm-3-d0b8.jpg-invaddpicsinvv|/addpics|
