You might need to copy HPQFLASH into the root of the disk partition along with the BIOS (Rom.bin) which needs to be compressed into “Rom.cab”. This is the only file the utility accepts. In order to compress your BIOS into .cab, you need to run makecab on it via CMD. “ver.txt” file might also need to be included into the cab file.
I don’t remember how I revived my first HDX9000 either by using a pendrive or floppy, you can give it a go with a pendrive of up to 1-2GB (better with a LED indicator to watch for the activity).
Hello. BIOS on my HDX9200 was damaged during an upgrade from F.35 to F.40.
Would someone please help me find a way to flash it and repair?
I have tried multiple procedures and none have succeeded so far.
I would really appreciate your help.
Thank you for the quick reply!
I will get a floppy drive and a floppy first
Hopefully it will do the trick.
USB does not react at all, so I am a bit pesimistic about this solution. CD-ROM kicks in, so maybe I will also try to burn a CD.
I tried to find the old HP HDX 9000 DRAGON Owners Lounge, on NotebookReview, but I see that’s long since closed down and this seems to be the next best place to post this:
I’m having a clear-out and I have a few Dragons and loads of HDX9000 parts in a bag, that I’m unlikely to ever put to good use.
As I recall, I have at least one fully operational Dragon and more than enough spares to build more, including screens and bezels.
I’d like all of this to go to an enthusiast, who will enjoy building a new Dragon or two.
Would anyone in here be interested?
CJ
This is what I used to have on my signature on Notebook Forum. Can’t be sure that I have all of this still, but I might…
HP HDX9250EA, HDX9320, (2nd)HDX9250EA, HDX9160EA and HDX9120EA
Intel Core 2 Extreme X9000 (3.8GHz) and T9300 3.3GHz (Throttlestop and FSB O/C 242MHz)
Windows 7 64bit
8192MB memory in two of the Dragons
128GB OCZ Vertex SSD with 640GB Spinpoint 7200RPM
60GB OCZ Vertex 2 SSD with 750GB WD Scorpio Black 7200RPM
WSXGA 1680x1050 and WUXGA 1920x1200
NVIDIA 8800M GTS (3), ATi GPU (2)
Panasonic UJ-220 Blu-Ray Burner and UJ-120 Blu-Ray Combo Drive.
(2nd)HP HDX9250EA, HDX9120EA & HDX9160EA are Bog Standard.
Glad I found this forum. I too was sad when I saw the owners lounge shut down. I have two of these laptops with different goals for each that I’m hoping I can get some assistance on. I got one new when they came out with the 8800GTS and T9300 that’s pretty much in mint condition, and just recently got one with the core 2 extreme X7800 and ATI (don’t know exactly which model) gpu that’s in pretty rough shape. I already tore the ATI one down all the way it was filled with dirt and dust so first step is to just clean that one. My dilemma I’m faced with is that the 8800GTS with the latest drivers causes bluescreens so I have to run older drivers but it’s still pretty lacking in performance. I also swapped out the wifi card for an AC card which connects at 1.3Gbps but when you try to do any large file transfer it’s slow and disconnects. I have also put in a bluray drive. Everything else is stock running Windows 10 with 4GB ram (I tried some no name ram to get up to 8GB but it was less stable). I was thinking about doing a GPU swap with the ATI or maybe just swap the whole board since I think the extreme CPU is slightly faster. Though I may just keep it as is.
The rough second one I was thinking about putting a framework 13 board in there. The keyboard, mouse, and side ports should be fairly easy to adapt or change, but what I think is going to be the biggest hurdle is getting the screen to work. I’ve been trying to figure out what kind of driver board I need but I don’t know how to tell which one will work. The plug is a 50 pin plug and what I’ve found is that LVDS may be a standard also might not be the right standard. Any help here would be appreciated.
I tried to flash the modded BIOS to one of my systems. The flash utility under W10x64 gives me “Failed to load driver” and under Vista32bit it bluescreens. I also struggle with the makecab - it gives me errors when I try to convert the modified BIOS. Could you help? Thanks!
Thank you, now I have a cab file, but the HPQFLASH still doesn’t work. Tried W10x64, W7x64 both say - “Failed to load driver”, on Vista32bit it crashes. Now looking for W7 32bit just to check if it’s going to work. BTW HPQFLASH was downloaded from this thread.
I have intel x9000 on hp hdx9200 and i am wondering what’s stopping DDR3 ram working on this? Apparently it supports it? Is this right? So i can put sodimm ddr3 and it should work? or will bios stop from working?
