Hi,
just want ask if it is possible somehow update, change the gpu bios for this card. I read some threads here but nothing what brought me some results. I tried flash rom from Razer RTX 2070 max-q, where are higher frequencies and bigger TDP. Please dont do that. You will lose your PC. PC works but no any display output, any port for display didnt work. I thought that i can go directly to the HP service center. I did the flash from backup blindly with help of my destop pc, step by step. Second try was successful. Uff, i was lucky.
Any idea?
What i read is, that nvidia start encrypt their bios, so it wont be so easy.
