One more chinese PC (fanless). After a year of usage starts turning off every 30 minutes. After googling I’m here and asking for help
Tried to:
- set “ME FW Image Re-Flash” in BIOS SETUP to Enabled
- reflash BIOS (from some chinese page), everything seems to be OK, but it doesn’t help to prevent shutdowns.
- write only ME region from this forum (Intel ME Firmware v9.5.60.1952) - fpt asks about size difference (2 MB in flash, 1.5 MB of file) - flashed, but no effect;
in BIOS Setup:
ME FW Version N/A
ME FW Mode Normal Mode
ME Firmware SKU N/A
fpt output:
Intel (R) Flash Programming Tool. Version: 10.0.30.1054
Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
Platform: Intel(R) Premium Express Chipset
Reading HSFSTS register… Flash Descriptor: Valid
— Flash Devices Found —
W25Q64BV ID:0xEF4017 Size: 8192KB (65536Kb)
— Flash Image Information –
Signature: VALID
Number of Flash Components: 1
Component 1 - 8192KB (65536Kb)
Regions:
Descriptor - Base: 0x000000, Limit: 0x000FFF
BIOS - Base: 0x200000, Limit: 0x7FFFFF
ME - Base: 0x001000, Limit: 0x1FFFFF
GbE - Not present
PDR - Not present
Master Region Access:
CPU/BIOS - ID: 0x0000, Read: 0xFF, Write: 0xFF
ME - ID: 0x0000, Read: 0xFF, Write: 0xFF
GbE - ID: 0x0118, Read: 0xFF, Write: 0xFF
Total Accessable SPI Memory: 8192KB, Total Installed SPI Memory : 8192KB
FPT Operation Passed
MEInfo output:
Intel(R) MEInfo Version: 9.5.35.1850
Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
FW Status Register1: 0x00003406
FW Status Register2: 0x00090000
FW Status Register3: 0x00000000
FW Status Register4: 0x00000000
FW Status Register5: 0x00000000
FW Status Register6: 0x00000000
CurrentState: Disabled and waiting to timeout
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: Transitioning
InitComplete: Initializing
BUPLoadState: Failure
ErrorCode: Image Failure
ModeOfOperation: Normal
Phase: ROM/Preboot
ICC: No valid OEM data, ICC not programmed
ME File System Corrupted: No
PhaseStatus: MANIFEST_FOUND
FPF and ME Config Status: Not committed
HECI device is found to be disabled.
Error 9256: Communication error between application and Intel(R) ME module (FW Update client)
SMBIOS Table Data
SM BIOS Spec Version : 2.8
Starting address: 0x E9860
Table Size in Bytes: 3371 ( 0xD2B )
Number of Table Entries: the 79 ( 0x4F )
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
SMBIOS Table Data
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 25 (0x 19 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 10 ( 0x 0A ) found, size of 6 (0x 06 ) bytes
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 12 ( 0x 0C ) found, size of 5 (0x 05 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 34 ( 0x 22 ) found, size of 11 (0x 0B ) bytes
Table Type 26 ( 0x 1A ) found, size of 22 (0x 16 ) bytes
Table Type 36 ( 0x 24 ) found, size of 16 (0x 10 ) bytes
Table Type 35 ( 0x 23 ) found, size of 11 (0x 0B ) bytes
Table Type 28 ( 0x 1C ) found, size of 22 (0x 16 ) bytes
Table Type 27 ( 0x 1B ) found, size of 15 (0x 0F ) bytes
Table Type 29 ( 0x 1D ) found, size of 22 (0x 16 ) bytes
Table Type 39 ( 0x 27 ) found, size of 22 (0x 16 ) bytes
Table Type 41 ( 0x 29 ) found, size of 11 (0x 0B ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 4 ( 0x 04 ) found, size of 42 (0x 2A ) bytes
Table Type 221 ( 0x DD ) found, size of 12 (0x 0C ) bytes
Table Type 16 ( 0x 10 ) found, size of 23 (0x 17 ) bytes
Table Type 17 ( 0x 11 ) found, size of 34 (0x 22 ) bytes
Table Type 19 ( 0x 13 ) found, size of 31 (0x 1F ) bytes
Table Type 20 ( 0x 14 ) found, size of 35 (0x 23 ) bytes
Table Type 221 ( 0x DD ) found, size of 54 (0x 36 ) bytes
Table Type 221 ( 0x DD ) found, size of 68 (0x 44 ) bytes
Table Type 221 ( 0x DD ) found, size of 26 (0x 1A ) bytes
Table Type 136 ( 0x 88 ) found, size of 6 (0x 06 ) bytes
Table Type 13 ( 0x 0D ) found, size of 22 (0x 16 ) bytes
Table Type 14 ( 0x 0E ) found, size of 17 (0x 11 ) bytes
Table Type 127 ( 0x 7F ) found, size of 4 (0x 04 ) bytes
Error 9459: Internal error (Could not determine FW features information)
Heeeeelp!!!
GBDW1108.zip (3.21 MB)
