So I am trying to upgrade to the anniversary edition of windows 10 from 1511-1607. Upon spending 12 hours with microsoft and them remotely taking over my computer, they told me that I was not able to upgrade until i take my computer to a local computer guy to fix the raid controller on my computer and reformat my disks. Now, everything is healthy and operating, but i wanted to come here to ask for advice or a simple fix to help me install this update by myself. Is there anyway to disable the raid controller or a way around it? Please help! I have an asus g10aj prebuilt computer on an intel raid controller. I hope this helps!
https://1drv.ms/i/s!AtVxaRcNF_FJjGJA79kqAavZppmL
@oartnick :
Welcome at Win-RAID Forum!
If you want help, you should give us some additional informations:
1. Chipset of your system
2. Location of your system drive (inside or outside the RAID array?)
3. Sort of your Intel RAID array
4. Version of the Intel RAID ROM resp. EFI "RaidDriver"
5. Version of the installed Intel RAID driver
6. Version of the installed Intel RAID Console Software
By the way: What has your help request to do with the Sub-Forum "Specific: NVIDIA nForce AHCI/RAID Drivers"?
Furthermore the thread title you had chosen is neither very meaningful nor specific enough.
Regards
Dieter (alias Fernando)
