I wanted to update my IME FW. But i am not sure about a few things:
I just installed a fresh Win 8.1 (with update) X64 on that ASRock H87Pro4. I uploaded an image and as you can see: FW Version is: 9.0.30.1482 SW: i installed latest i could find: 10.0.30.1054
Questions: 1.) Latest FW is IME 9.0.31.1487, right? 2.) i HAVE TO use 5MB (Business) Images? or 1.5 MB? 3.) can i use the latest drivers or should i get back to older version (because of my chipset and FW)? 4.) UEFI Installation of windows 8.1 x64 => update only in DOS mode (like USB freedos boot and update)?
Thanks for any help.
PS: found the changelog (attached too) of the 9.0.31.1487 FW and it is mentioned: - Added support for Microsoft Windows 8.1 64-bit.
So the FW i already have, does not support the OS i already have installed?!?
H97 is the 9 Series platform, so the me firmare is 9.1, H87 is 8 series desktop chipsets, so management engine firmware is 9.0, and the 8 series mobile chipset is 9.5
when I save my old FW i get a file which is 3,88MB. So do i need the 5MB one?
When i read this (IME Update failed) i get the impression i have to take the 5MB (he has the H97 Pro4, i have the H87 Pro4). And MEInfoWin gives me: “small business technology”.
So the 5MB then? -------------------------- Just used the 5MB (since i git invalid file error). Worked restarting now
EDIT by Fernando: Quoted text deleted (to save space and to avoid misunderstandings by future visitors of the Forum, because my answer regarding the suitable Intel ME Firmware 1.5MB/5M variant was wrong)
Good, everything mentioned above is correct. Don’t forget to check after the update that everything is working great by running MEInfo (should not report any errors) and MEManuf (should report “MEManuf Operation Passed”).
This operating system “compatibility” is not really important, you wouldn’t be facing any problems either way.
