Infos on B550
Hey!
That’s probably a stupid question but I need to know :wink:
Is it possible to remove one of the CPU microcode from the bios and replace it with one that is not supported officially by the board?
Or just adding it?
If it’s not possible, can someone explain why exactly?
Here’s my bios info:
256Mb AMI UEFI Legal BIOS with GUI support
Supports "Plug and Play"
ACPI 5.1 compliance wake up events
SMBIOS 2.3 support
Supports jumperfree
CPU, CPU VDDCR_SOC, DRAM, VPPM, VTT_DDR Offset, CPU VDD 1.8 Voltage Multi-adjustment
As you might have noticed already, I want to be able to use my Ryzen 5 2600 on a B550 board and at the same time, I always wanted to mod a bios.
