Just curious…My last flash on Asus Z270 mb was 11.8.55.3510_CON_H_D0_PRD_RGN.bin and the new flash 11.8.60.3560_CON_H_D0_PRD_EXTR.bin.I take it mine has to say RGN.bin and the EXTR.bin is not for me or is this safe to flash.Thought to ask fist before trying anything…
@NIK1 :
According to the “Firmware Type” lines of the screenshots, which have been attached by plutomaniac >here<, “RGN” seems to mean “REGION, Stock” and “EXTR” obviously means “Region, EXTRACTED”.
Thanks Fern,so the 11.8.60.3560_CON_H_D0_PRD_EXTR.bin is go to go for me…
The Intel ME Firmware has to be flashed, whereas the Intel MEI Software and the related driver can normally be installed from within the Operating System.
@plutomaniac ,
Trying to configure 12.0.10.1127 for flashing and have a couple questions if you don’t mind:
1. The instructions said that you need to input the PMC Region binary into the ME with FIT at the Intel(R) Me and Pmc Region > PMC Binary File step. So I decomposed my full bios file provided by the manufacturer of my mainboard with FIT and used ‘PMC Region.bin’ as the input file in 12.0.10.1127 using FIT. Is that correct because the resulting ME file according to ME analyzer doesn’t have the latest PMC ?
2. Opening up 12.0.10.1127 in Fit resulted in these errors:
Warning: Invalid value specified for “GbE PCIe Port Select”: Port13, reverting to previous/default value: Port 13
Warning: Invalid value specified for “eSPI / EC Slave Attached Flash Multiple Outstanding Requests Enable”: Single, reverting to previous/default value: Single Outstanding Request
Warning: Invalid value specified for “eSPI / EC Slave Attached Flash Channel OOO Enable”: In Order, reverting to previous/default value: In-Order SAF Requests
Warning: Invalid value specified for “USB2 DbC port enable”: No USB3 Ports, reverting to previous/default value: No USB2 Ports
Warning: Invalid value specified for “Intel(R) Precise Touch and Stylus Controller 1 Maximum Frequency”: 30MHz, reverting to previous/default value: 30 MHz
So I changed each one to match what there was in my original bios file changing port 13 to port 5 for example. Is that correct?
After that I followed the rest of the instructions changing the top detail to Intel ConnonLake H Series - Z390 and number of flash components to 0 and built the ME rom file.
Am I ready to flash? I am attaching my final file for review. Change extension from .doc to .bin.
Thank you.
Edit: Found the list of newer PMC files and used the newer one instead. Attached my final final rom file:
Thank you
cse_image_FWU_Full.doc (2.45 MB)
cse_image_FWU_Full_pmc.doc (2.45 MB)
@ davidm71:
Firmware settings do not matter when using FWUpdate tool so you don’t have to change anything. Take the CSME firmware (RGN/EXTR), stitch the compatible PMC firmware and flash the resulting image via FWUpdate tool, as explained at the first post. If you want to create a proper SPI image for use with a programmer, FPT etc then you need to follow the Engine CleanUp Guide instead.
@plutomaniac ,
I guess I’m going to go for it then. Wish me luck…
Thanks
It should work just fine. Show us a MEInfo -verbose output once you’re done to be sure.
Flash went well. MEinfo didn’t report errors as far as I could tell. Was able to reboot. Thank you.
Out of caution, need to ask - if I upgrade using FWUPDLCL, it is the same whether I use RGN or EXTR file?
I’m confused. The Intel CSME 11.8 Consumer PCH-H Firmware v11.8.60.3560 firmware from OP is an EXTR firmware and I was told we shouldn’t use EXTR firmware to flash on our systems.
@Fernando ,
the 2 MEI v1839.12.xxx software links offered do not provide the expected piece of software. is it normal ?
only pure v1839 branch driver are ok.
@100PIER :
Why did you address your question to me?
The start post of this thread has been written and the links have been inserted by @plutomaniac .
By the way - for me all the related links seem to be ok.
You are right, the message is for @plutomaniac
Into the start post A3, the two links v1839.12.0.1165 does point to v12.0.1165 drivers and software.
This is confusing to have on one site v1839.xxx naming and on one other site the v12.xxx naming. The both naming should be in synch.
@plutomaniac ,
If I flash a newer bios version but the ME is older than I recently flashed will my new ME file get over written by the newer bios file on a Gigabyte Z390 board?
Thanks Pluto
To anyone with a CSME 12 system, please post a MEInfo > “MEInfoWin64.exe -verbose” as well as a Clock Commander Tool > “cctwin.exe gcc” output.
Intel MEI v1847.12.0.1183 for Corporate systems Drivers & Software
Intel MEI Driver v1828.12.0.1152 (Windows 8 & Windows 10) INF
Intel SOL “Driver” v1843.12.0.1169 INF
Intel CSME 11.8 Consumer PCH-LP Firmware v11.8.60.3561
Intel CSME 11.8 Corporate PCH-LP Firmware v11.8.60.3561
Intel CSME System Tools v11 r17
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
Intel(R) MEInfo Version: 12.0.10.1127
Copyright(C) 2005 - 2018, Intel Corporation. All rights reserved.
Windows OS Version : 10.0
FW Status Register1: 0x90000255
FW Status Register2: 0x02F10506
FW Status Register3: 0x00000020
FW Status Register4: 0x00004804
FW Status Register5: 0x00000000
FW Status Register6: 0x00000006
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Present
Phase: ROM/Preboot
ME File System Corrupted: No
PhaseStatus: PROTECTED_START
FPF and ME Config Status: Not committed
FW Capabilities value is 0x11109140
Feature enablement is 0x11109140
Platform type is 0x72000392
Found an Intel non-vPro Wireless device
Intel(R) ME code versions:
Table Type 0 ( 0x 00 ) found, size of 0 (0x 00 ) bytes
BIOS Version 1.22
Table Type 0 ( 0x 00 ) found, size of 68 (0x 44 ) bytes
Table Type 1 ( 0x 01 ) found, size of 120 (0x 78 ) bytes
Table Type 2 ( 0x 02 ) found, size of 123 (0x 7B ) bytes
Table Type 3 ( 0x 03 ) found, size of 107 (0x 6B ) bytes
Table Type 8 ( 0x 08 ) found, size of 25 (0x 19 ) bytes
Table Type 9 ( 0x 09 ) found, size of 23 (0x 17 ) bytes
Table Type 11 ( 0x 0B ) found, size of 21 (0x 15 ) bytes
Table Type 12 ( 0x 0C ) found, size of 21 (0x 15 ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 34 ( 0x 22 ) found, size of 19 (0x 13 ) bytes
Table Type 26 ( 0x 1A ) found, size of 29 (0x 1D ) bytes
Table Type 36 ( 0x 24 ) found, size of 18 (0x 12 ) bytes
Table Type 35 ( 0x 23 ) found, size of 27 (0x 1B ) bytes
Table Type 28 ( 0x 1C ) found, size of 29 (0x 1D ) bytes
Table Type 27 ( 0x 1B ) found, size of 30 (0x 1E ) bytes
Table Type 27 ( 0x 1B ) found, size of 17 (0x 11 ) bytes
Table Type 29 ( 0x 1D ) found, size of 27 (0x 1B ) bytes
Table Type 39 ( 0x 27 ) found, size of 184 (0x B8 ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 109 (0x 6D ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 221 ( 0x DD ) found, size of 93 (0x 5D ) bytes
Table Type 221 ( 0x DD ) found, size of 388 (0x 184 ) bytes
Table Type 221 ( 0x DD ) found, size of 208 (0x D0 ) bytes
Table Type 7 ( 0x 07 ) found, size of 29 (0x 1D ) bytes
Table Type 4 ( 0x 04 ) found, size of 185 (0x B9 ) bytes
Table Type 20 ( 0x 14 ) found, size of 37 (0x 25 ) bytes
MEBx Version 0.0.0.0000
GbE Version Unknown
PMC FW Version 300.2.11.1018
Descriptor Version 1.0
Vendor ID 8086
FW Version 12.0.10.1127 H Consumer
LMS Version Not Available
MEI Driver Version 1828.12.0.1152
Wireless Hardware Version 2.1.77
Wireless Driver Version 20.100.0.4
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
PCH SKU Type Production Pre-QS Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x11109140
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) Platform Trust Technology - NOT PRESENT
Persistent RTC and Memory - PRESENT/ENABLED
FW Type Production
TLS Disabled
Last ME reset reason Global system reset
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Get flash master region access status...done
Host Read Access to ME Enabled
Host Write Access to ME Enabled
Get EC region access status...done
Host Read Access to EC Enabled
Host Write Access to EC Enabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 EF4018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
EPID Group ID 0x28BC
Keybox Not Provisioned
Intel(R) PTT Supported No
Intel(R) PTT initial power-up state Disabled
PAVP Supported Yes
Integrated Sensor Hub Initial Power State Disabled
End of Manufacturing Enable No
Post Manufacturing NVAR Config Enabled Yes
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 4
Trusted Computing Base SVN 1
ACM SVN FPF 0x00
KM SVN FPF 0x00
BSMM SVN FPF 0x00
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
HW Binding Enabled
FPF UEP ME FW
*In Use
Key Manifest ID Not set 0x00 0x00
PTT Not set Enabled Enabled
SPI Boot Source Not set Enabled Enabled
Enforcement Policy Not set 0x00 0x00
OEM ID Not set 0x00 0x00
TXT Supported Disabled Disabled Disabled
OEM Key Manifest Present Not Present Not Present Not Present
OEM Platform ID Not set 0x00 0x00
SOC Config Lock Not set Not Done Not Done
Persistent PRTC Backup Power Enabled Enabled Enabled
CPU Debugging Not set Disabled Disabled
BSP Initialization Not set Disabled Disabled
Measured Boot Not set Disabled Disabled
Verified Boot Not set Disabled Disabled
Protect BIOS Environment Not set Disabled Disabled
Intel (R) Clock Commander Tool Version: 12.0.7.1122
Copyright (C) 2009 - 2018 Intel Corporation. All rights reserved.
HW Product Family:CNP-H
FW Version Major: 12
FW Version Minor: 0
FW Version Hotfix: 10
FW Version Build: 1127
ICC HW SKU = EXTREME
HECI CMD Status = 0x00000000 (SUCCESS)
Don’t know if you need it, but here is one more 12.x MEInfo & CCT output.
FW Status Register2: 0x00F10506
ErrorCode: No Error
Phase: ROM/Preboot
FW Capabilities value is 0x31119140
Feature enablement is 0x11119140
No Intel Wireless device was found
BIOS Version 1.20
Table Type 2 ( 0x 02 ) found, size of 131 (0x 83 ) bytes
Table Type 17 ( 0x 11 ) found, size of 74 (0x 4A ) bytes
GbE Version Unknown
Vendor ID 8086
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
FW Capabilities 0x31119140
Intel(R) Platform Trust Technology - PRESENT/DISABLED
FW Type Production
TLS Disabled
Get flash master region access status…done
Get EC region access status…done
SPI Flash ID 1 C22018
OEM Tag 0x00000000
EPID Group ID 0x28BA
Intel(R) PTT Supported Yes
PAVP Supported Yes
ACM SVN FPF 0x00
KM SVN FPF 0x00
BSMM SVN FPF 0x00
HW Binding Enabled
FPF UEP ME FW
*In Use
EK Revoke State Not Revoked Not Revoked Not Revoked
FW Version Minor: 0
Heres mine:
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
FW Status Register2: 0x06F10506
FW Status Register4: 0x00004000
FW Status Register6: 0x00400000
ErrorCode: No Error
SPI Flash Log: Not Present
Phase: ROM/Preboot
FW Capabilities value is 0x31109140
BIOS Version F6
Table Type 0 ( 0x 00 ) found, size of 66 (0x 42 ) bytes
Table Type 1 ( 0x 01 ) found, size of 136 (0x 88 ) bytes
Table Type 2 ( 0x 02 ) found, size of 116 (0x 74 ) bytes
Table Type 3 ( 0x 03 ) found, size of 98 (0x 62 ) bytes
Table Type 10 ( 0x 0A ) found, size of 33 (0x 21 ) bytes
GbE Version 0.5
Vendor ID 8086
LMS Version 1828.12.0.1150
MEI Driver Version 1815.12.0.2021
Wireless Driver Version 20.70.0.5
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
FW Capabilities 0x31109140
FW Type Production
TLS Disabled
Last ME reset reason Firmware reset
OEM Tag 0x00000000
PAVP Supported Yes
ACM SVN FPF 0x00
KM SVN FPF 0x00
BSMM SVN FPF 0x00
OEM Public Key Hash UEP E02EFA655BEBB704883EEE4476ADC62C6FEBC80756158CB684A71D35B169C5D1
OEM Public Key Hash ME FW E02EFA655BEBB704883EEE4476ADC62C6FEBC80756158CB684A71D35B169C5D1
HW Binding Enabled
FPF UEP ME FW
*In Use
Key Manifest ID Not set 0x01 0x01
OEM Key Manifest Present Not Present Present Present
CPU Debugging Not set Enabled Enabled
BSP Initialization Not set Enabled Enabled
FW Version Minor: 0
Wish someone would answer my inquiry couple posts back but does not matter now going to flash and see.
Thanks
Thank you a lot guys. For now, the more outputs the better. Hopefully some PCH-LP peeps will pitch in as well. It seems that the Clock Commander Tool does not report anymore what I want to see (PCH Stepping) but I think it did in the past. Can you check with the attached versions?
@ davidm71:
Depends on the Flash Descriptor state and the flasher’s capabilities.
CCT.rar (111 KB)
