@ plutomaniac
Tested the three CCT versions you attached, but unfortunately the same output as the first report, no PCH Stepping.
There are three different versions in that rar file. You want all three??
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
Intel (R) Clock Commander Tool Version: 12.0.5.1117
Copyright (C) 2009 - 2018 Intel Corporation. All rights reserved.
HW Product Family:CNP-H
FW Version Major: 12
FW Version Minor: 0
FW Version Hotfix: 10
FW Version Build: 1127
ICC HW SKU = EXTREME
HECI CMD Status = 0x00000000 (SUCCESS)
Intel (R) Clock Commander Tool Version: 12.0.6.1120
FW Version Minor: 0
Intel (R) Clock Commander Tool Version: 12.0.20.1301
FW Version Minor: 0
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
Intel(R) MEInfo Version: 12.0.10.1127
Copyright(C) 2005 - 2018, Intel Corporation. All rights reserved.
Windows OS Version : 10.0
FW Status Register1: 0x94000255
FW Status Register2: 0x02F10506
FW Status Register3: 0x00000020
FW Status Register4: 0x00004804
FW Status Register5: 0x00000000
FW Status Register6: 0x00000006
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Present
Phase: ROM/Preboot
ME File System Corrupted: No
PhaseStatus: PROTECTED_START
FPF and ME Config Status: Not committed
FW Capabilities value is 0x11109140
Feature enablement is 0x11109140
Platform type is 0x72000392
Found an Intel non-vPro Wireless device
Intel(R) ME code versions:
Table Type 0 ( 0x 00 ) found, size of 0 (0x 00 ) bytes
BIOS Version 1.22
Table Type 0 ( 0x 00 ) found, size of 68 (0x 44 ) bytes
Table Type 1 ( 0x 01 ) found, size of 120 (0x 78 ) bytes
Table Type 2 ( 0x 02 ) found, size of 123 (0x 7B ) bytes
Table Type 3 ( 0x 03 ) found, size of 107 (0x 6B ) bytes
Table Type 8 ( 0x 08 ) found, size of 25 (0x 19 ) bytes
Table Type 9 ( 0x 09 ) found, size of 23 (0x 17 ) bytes
Table Type 11 ( 0x 0B ) found, size of 21 (0x 15 ) bytes
Table Type 12 ( 0x 0C ) found, size of 21 (0x 15 ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 34 ( 0x 22 ) found, size of 19 (0x 13 ) bytes
Table Type 26 ( 0x 1A ) found, size of 29 (0x 1D ) bytes
Table Type 36 ( 0x 24 ) found, size of 18 (0x 12 ) bytes
Table Type 35 ( 0x 23 ) found, size of 27 (0x 1B ) bytes
Table Type 28 ( 0x 1C ) found, size of 29 (0x 1D ) bytes
Table Type 27 ( 0x 1B ) found, size of 30 (0x 1E ) bytes
Table Type 27 ( 0x 1B ) found, size of 17 (0x 11 ) bytes
Table Type 29 ( 0x 1D ) found, size of 27 (0x 1B ) bytes
Table Type 39 ( 0x 27 ) found, size of 184 (0x B8 ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 109 (0x 6D ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 221 ( 0x DD ) found, size of 93 (0x 5D ) bytes
Table Type 221 ( 0x DD ) found, size of 388 (0x 184 ) bytes
Table Type 221 ( 0x DD ) found, size of 208 (0x D0 ) bytes
Table Type 7 ( 0x 07 ) found, size of 29 (0x 1D ) bytes
Table Type 4 ( 0x 04 ) found, size of 185 (0x B9 ) bytes
Table Type 20 ( 0x 14 ) found, size of 37 (0x 25 ) bytes
MEBx Version 0.0.0.0000
GbE Version Unknown
PMC FW Version 300.2.11.7019
Descriptor Version 1.0
Vendor ID 8086
FW Version 12.0.20.1303 H Consumer
LMS Version Not Available
MEI Driver Version 1828.12.0.1152
Wireless Hardware Version 2.1.77
Wireless Driver Version 20.100.0.4
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
PCH SKU Type Production Pre-QS Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x11109140
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) Platform Trust Technology - NOT PRESENT
Persistent RTC and Memory - PRESENT/ENABLED
FW Type Production
TLS Disabled
Last ME reset reason Global system reset
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Get flash master region access status...done
Host Read Access to ME Enabled
Host Write Access to ME Enabled
Get EC region access status...done
Host Read Access to EC Enabled
Host Write Access to EC Enabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 EF4018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
EPID Group ID 0x28BC
Keybox Not Provisioned
Intel(R) PTT Supported No
Intel(R) PTT initial power-up state Disabled
PAVP Supported Yes
Integrated Sensor Hub Initial Power State Disabled
End of Manufacturing Enable No
Post Manufacturing NVAR Config Enabled Yes
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 4
Trusted Computing Base SVN 1
ACM SVN FPF 0x00
KM SVN FPF 0x00
BSMM SVN FPF 0x00
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
HW Binding Enabled
FPF UEP ME FW
*In Use
Key Manifest ID Not set 0x00 0x00
PTT Not set Enabled Enabled
SPI Boot Source Not set Enabled Enabled
Enforcement Policy Not set 0x00 0x00
OEM ID Not set 0x00 0x00
TXT Supported Disabled Disabled Disabled
OEM Key Manifest Present Not Present Not Present Not Present
OEM Platform ID Not set 0x00 0x00
SOC Config Lock Not set Not Done Not Done
Persistent PRTC Backup Power Enabled Enabled Enabled
CPU Debugging Not set Disabled Disabled
BSP Initialization Not set Disabled Disabled
Measured Boot Not set Disabled Disabled
Verified Boot Not set Disabled Disabled
Protect BIOS Environment Not set Disabled Disabled
cse_image_FWU_Full for flash Intel Firmware Update Utility.
Region_ME_12.0.20.1303.zip (1.66 MB)
cse_image_FWU_Full.zip (1.66 MB)
Intel CSME 12.0 Consumer PCH-H Firmware v12.0.20.1303
Intel CSME System Tools v12 r12
Hey, @jjxaker bro. Where did you get that PMC firmware of 300.2.11.7019 version?
Exactly, that is what I would like to know as well
@Wickez
I laid out cse_image_FWU_Full, this will update the ME FW + PMC FW. FWUpdLcl64 -f cse_image_FWU_Full.bin -forcereset
Or what else would you like to know? of course everything is pulled from the image of the new bios…
Quick note: whenever you see the Build version starting with 7xxx, that image is some sort of test. In this case, 7019 is a test based on 1019. For example, if we find 1020 in the future, it will be newer than 7019. For the time being, 7019 is technically newer than the 1018 we have but I decided to not post it at the first post just in case it is unstable.
Hmm, I will wait for the official release of PMC firmware to update with the newer ME firmware, then. Thanks for the hint.
@Wickez This forum just exists to not wait for anything officially Especially, for example, Asus does not update almost anything at all, except a couple of times a year…
@tadekm
As a follow up to this log you provided a few months ago, could you re-download the latest Intel CSME System Tools v12 and show us a “MEInfo -verbose” output again from your H370 system?
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
PS C:\Users\Tadek\Downloads\Intel CSME System Tools v12 r12\MEInfo\WIN64> .\MEInfoWin64.exe -verbose
Intel (R) MEInfoWin64.exe Version: 12.0.20.1301
Copyright (C) 2005 - 2018, Intel Corporation. All rights reserved.
LPC Device Id: A304.
Platform: Cannonlake Platform
FW Status Register1: 0x90000245
FW Status Register2: 0x00F10506
FW Status Register4: 0x00004000
FW Status Register6: 0x40000000
ManufacturingMode: Disabled
ErrorCode: No Error
SPI Flash Log: Not Present
Phase: ROM/Preboot
PhaseStatus: UNKNOWN
FPF and ME Config Status: Committed
RPMC status: OK
FW Capabilities value is 0x31109140
Feature enablement is 0x31109140
Table Type 255 ( 0x FF ) found, size of 0 (0x 00 ) bytes
BIOS Version P3.10
Table Type 0 ( 0x 00 ) found, size of 69 (0x 45 ) bytes
Table Type 1 ( 0x 01 ) found, size of 166 (0x A6 ) bytes
Table Type 2 ( 0x 02 ) found, size of 125 (0x 7D ) bytes
Table Type 3 ( 0x 03 ) found, size of 138 (0x 8A ) bytes
Table Type 11 ( 0x 0B ) found, size of 29 (0x 1D ) bytes
Table Type 40 ( 0x 28 ) found, size of 22 (0x 16 ) bytes
Table Type 17 ( 0x 11 ) found, size of 74 (0x 4A ) bytes
Table Type 221 ( 0x DD ) found, size of 32 (0x 20 ) bytes
Table Type 4 ( 0x 04 ) found, size of 189 (0x BD ) bytes
Table Type 130 ( 0x 82 ) found, size of 22 (0x 16 ) bytes
MEBx Version 12.0.0.0009
GbE Version 0.5
Vendor ID 8086
FW Version 12.0.6.1120 H Consumer
LMS Version 1846.12.0.1173
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
PMC FW Version 300.2.11.1015
PCH Information
PCH Version 10
PCH Device ID A304
PCH Step Data B1
FW Capabilities 0x31109140
Intel(R) Platform Trust Technology - PRESENT/ENABLED
End of Manufacturing Enable Yes
Intel(R) PTT Supported Yes
Intel(R) PTT initial power-up state Enabled
OEM Tag 0x00
PAVP Supported Yes
TLS Disabled
FW Type Production
Last ME reset reason Unknown
Host Write Access to ME Disabled
Trusted Computing Base SVN 0
HW Binding Enabled
FPF UEP ME FW
Enforcement Policy 0x00 0x00 0x00
EK Revoke State Not Revoke Not Revoke Not Revoke # Not Revoke=0, Revoke=1
PTT Enabled Enabled Enabled # Disabled=0, Enabled=1
OEM ID 0x00 0x00 0x00
OEM Key Manifest Present Not Present Not Present Not Present # Not Present=0, Present=1
OEM Platform ID 0x00 0x00 0x00
OEM Secure Boot Policy 0x00 0x00 0x00
CPU Debugging Enabled Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Enabled Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Disabled Disabled Disabled # Disabled=0, Enabled=1
Measured Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Verified Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Key Manifest ID 0x00 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled Enabled # Enabled=0, Disabled=1
RPMB Migration Done Disabled Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock Done Not Done Done # Not Done=0, Done=1
SPI Boot Source Enabled Enabled Enabled # Enabled=0, Disabled=1
TXT Supported Disabled Disabled Disabled # Disabled=0, Enabled=1
ACM SVN FPF 0x00
BSMM SVN FPF 0x00
KM SVN FPF 0x00
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
PTT Lockout Override Counter FPF 0x01
Thank you very much for the new output @tadekm . It now makes sense. At the previous output (MEInfo 12.0.6.1120, CSME 12.0.0.1059, BIOS 3.00) the PCH Stepping was being reported as A0 (Ax) which makes no sense as the Production ones are Bx. The new log (MEInfo 12.0.20.1301, CSME 12.0.6.1120, BIOS 3.10) now shows the expected value of B1 (Bx). So this anomaly was probably a bug with MEInfo 12.0.6.1120, CSME 12.0.0.1059 or BIOS 3.00, depending on what’s responsible for reporting that info.
Added new instructions at Notice about CSME 12 FWUpdate Tool. Read the Notice of the first post again.
Power Management Controller (PMC) firmware are also defined by a Security Version Number (SVN). Big thanks to @Pacman for the discovery.
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.20.1301
Intel CSME 12.0 Consumer PCH-LP B Firmware v12.0.0.1062
Please download the latest version of ME Analyzer for the new field and new separated CSME/PMC output info:
Intel CSME 11.8 Consumer PCH-H Firmware v11.8.60.3561
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.20.1307
Intel CSME System Tools v12 r12 (2018-12-19)
Hello, I’m new here. I’ve just updated to Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.20.1307
Before update PhaseStatus = PROTECTED_START but now PhaseStatus = UNKNOWN
And also after running FWUpdate tool it created error.txt which said that verification is ok. I attach memanuf and cct reports
Is everything ok? Because that kinda worries me
@magikkk
Everything looks ok at MEManuf. Run MEInfo as well. Try a Flash Programming Tool “fptw64 -greset”, the system will restart. Afterwards, check if the Unknown value is gone.
