@plutomaniac ,
After updating ME firmware for ASUS Prime Z390M-Plus motherboard do we have also to update Intel ME FITC Version which does currently remain v12.0.6.1120 ?
If it is unuseful I let like displayed on the screenshot.
If it is useful, how do that ?
Hi,
I have Windows 10. Thanks.
Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.65.3572
I have a Z270 Asus Apex MB that has 11.8.60.3561_CON_H_D0_PRD_RGN.binā¦Would 11.8.65.3572_CON_H_DA_PRD_RGN.bin be the right file to upgrade toā¦I see a difference in the 3561 file it reads CON_H_D0_ where the 3572 has CON_H_DA .Whats the difference in D0 and DAā¦Just want to ask here first if its the right one before trying anything.
Even Station Drivers has not posted (1.5) 11.8.65.3572 firmware yet. Where do I get it then?
I would like to know that too
Hello everybody.
Can i safely update Intel ME firmware to v11.8.65.3572?
Meinfo
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
Ā
Intel(R) MEInfo Version: 11.8.60.3561
Copyright(C) 2005 - 2018, Intel Corporation. All rights reserved.
Ā
Ā
Windows OS Version : 10.0
Ā
FW Status Register1: 0x90000245
FW Status Register2: 0x00F60506
FW Status Register3: 0x00000020
FW Status Register4: 0x00084000
FW Status Register5: 0x00000000
FW Status Register6: 0x40000000
Ā
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
FPF HW Source value: Not Applicable
ME FPF Fusing Patch Status: ME FPF Fusing patch NOT applicable
Phase: ROM/Preboot
ICC: Valid OEM data, ICC programmed
ME File System Corrupted: No
PhaseStatus: AFTER_SRAM_INIT
FPF and ME Config Status: Match
FW Capabilities value is 0x31111540
Feature enablement is 0x11111140
Platform type is 0x71220322
No Intel Wireless device was found
Intel(R) ME code versions:
Ā
Table Type 5 ( 0x 05 ) found, size of 0 (0x 00 ) bytes
BIOS Version 3802
Table Type 0 ( 0x 00 ) found, size of 66 (0x 42 ) bytes
Table Type 1 ( 0x 01 ) found, size of 131 (0x 83 ) bytes
Table Type 2 ( 0x 02 ) found, size of 113 (0x 71 ) bytes
Table Type 3 ( 0x 03 ) found, size of 98 (0x 62 ) bytes
Table Type 8 ( 0x 08 ) found, size of 14 (0x 0E ) bytes
Table Type 9 ( 0x 09 ) found, size of 27 (0x 1B ) bytes
Table Type 10 ( 0x 0A ) found, size of 33 (0x 21 ) bytes
Table Type 11 ( 0x 0B ) found, size of 58 (0x 3A ) bytes
Table Type 12 ( 0x 0C ) found, size of 21 (0x 15 ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 34 ( 0x 22 ) found, size of 29 (0x 1D ) bytes
Table Type 26 ( 0x 1A ) found, size of 29 (0x 1D ) bytes
Table Type 36 ( 0x 24 ) found, size of 18 (0x 12 ) bytes
Table Type 35 ( 0x 23 ) found, size of 27 (0x 1B ) bytes
Table Type 28 ( 0x 1C ) found, size of 29 (0x 1D ) bytes
Table Type 27 ( 0x 1B ) found, size of 30 (0x 1E ) bytes
Table Type 27 ( 0x 1B ) found, size of 17 (0x 11 ) bytes
Table Type 29 ( 0x 1D ) found, size of 27 (0x 1B ) bytes
Table Type 39 ( 0x 27 ) found, size of 184 (0x B8 ) bytes
Table Type 40 ( 0x 28 ) found, size of 65 (0x 41 ) bytes
Table Type 41 ( 0x 29 ) found, size of 26 (0x 1A ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 113 (0x 71 ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 7 ( 0x 07 ) found, size of 29 (0x 1D ) bytes
Table Type 4 ( 0x 04 ) found, size of 188 (0x BC ) bytes
Table Type 20 ( 0x 14 ) found, size of 37 (0x 25 ) bytes
Table Type 130 ( 0x 82 ) found, size of 22 (0x 16 ) bytes
MEBx Version 0.0.0.0000
GbE Version 0.7
Vendor ID 8086
PCH Version 31
FW Version 11.8.60.3561 H
Security Version (SVN) 3
LMS Version Not Available
MEI Driver Version 1904.12.0.1208
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
Ā
FW Capabilities 0x31111540
Ā
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) NFC Capabilities - NOT PRESENT
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Ā
Re-key needed False
Platform is re-key capable True
TLS Disabled
Last ME reset reason Power up
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Get flash master region access status...done
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Get EC region access status...done
Host Read Access to EC Disabled
Host Write Access to EC Disabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 EF4018
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
Independent Firmware Recovery Disabled
EPID Group ID 0x1FBF
Ā
Retrieving Variable "LSPCON Port Configuration"
LSPCON Ports None
Ā
Retrieving Variable "eDP Port Configuration"
5K Ports None
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
Ā
Retrieving Variable "OEM Public Key Hash"
OEM Public Key Hash ME 0000000000000000000000000000000000000000000000000000000000000000
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
Ā
Retrieving Variable "GuC Encryption Key"
GuC Encryption Key ME 0000000000000000000000000000000000000000000000000000000000000000
Ā
FPF ME
Force Boot Guard ACM Disabled
Retrieving Variable "Force Boot Guard ACM Enabled"
Disabled
Protect BIOS Environment Disabled
Retrieving Variable "Protect BIOS Environment Enabled"
Disabled
CPU Debugging Enabled
Retrieving Variable "CPU Debugging"
Enabled
BSP Initialization Enabled
Retrieving Variable "BSP Initialization"
Enabled
Measured Boot Disabled
Retrieving Variable "Measured Boot Enabled"
Disabled
Verified Boot Disabled
Retrieving Variable "Verified Boot Enabled"
Disabled
Key Manifest ID 0x0
Retrieving Variable "Key Manifest ID"
0x0
Enforcement Policy 0x0
Retrieving Variable "Error Enforcement Policy"
0x0
PTT Enabled
Retrieving Variable "Intel(R) PTT Supported"
Enabled
PTT Lockout Override Counter 0x0
EK Revoke State Not Revoked
PTT RTC Clear Detection FPF 0x0
Ā
MeManu
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
Ā
Intel(R) MEManuf Version: 11.8.60.3561
Ā
Ā
Ā
ErrorCode: No Error
Phase: ROM/Preboot
Ā
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
OEM ICC data valid and programmed correctly
MFS is not corrupted
PCH SKU Emulation is correct
FPF and ME Config values matched
Ā
Request Intel(R) ME BIST status command... done
Ā
Get Intel(R) ME test data command... done
Ā
Total of 10 Intel(R) ME test result retrieved
Ā
Policy Kernel - Boot Guard : Self Test - Passed
MCA - MCA Tests : Blob - Passed
MCA - MCA Tests : MCA Manuf - Passed
SMBus - SMBus : Read byte - Passed
VDM - General : VDM engine - Passed
PAVP - General : Verify Edp and Lspcon Configurations - Passed
PAVP - General : Set Lspcon Port - Passed
PAVP - General : Set Edp Port - Passed
Ā
Clear Intel(R) ME test data command... done
Ā
Ā
MEManuf Operation Passed
Ā
Thanks
@NIK1 @Nyamp @ZyKLon
The old chipset naming scheme was D0, which is what Intel uses. It stands for Chipset Stepping D (3), Revision 0 (0) so 30. It is wrong though or misleading at best. The actual stepping for PCH-H 100-series is D1 (31 as you can see at MEInfo) and it does not account for the also supported PCH-H 200-series Stepping A. So the new one I use is DA = D,A which stands for SPT-H D and KBP/BSF-H A as you can see from MEA. They are the same.
@MonarchX
From what I hear the first post exists for a reason.
Thank you very much Sir.
Cheers
@plutomaniac
Any comment on my post #4399 ?
Flash Image Tool (FIT) is a tool, not something you can update. Read Section C of the OP.
Many Thanks plutomaniac, Yes, it does make sense, only Intel does update theirs tools.
hello guys my friend gave me his motherboard Asus Z87-A, i installed my cpu i5-4460, RX580 8gb nitro + , hdd 7200rpm toshiba, and psu, iām getting this error always i donāt know how to fix this, i tried windows 10 and now iām using windows 7 tried update latest bios 2103 from asus website, tried latests CHIPSET driver and also Intel ME driver, nothing works for me⦠https://imgur.com/a/4ggVyRz here is a screenshot. also iām very noob here in software related things, i can only click steam icon and play counter-strike global offensive =d
This is a forum for more advanced users so you might need some outside help or googling. As for the actual issue, install the latest v11.7 MEI-Only drivers from Section A1 of the OP and check if the problem persists after a restart. If it does, download Intel ME System Tools v9.1 from Section C of the OP, open a command prompt as administrator, run MEInfo tool with parameter ā-fwstsā and show us the result here.
thank u for ur response iām getting this error still https://imgur.com/O4GgxO3 This device cannot start. (code 10)
also downloaded Intel ME System Tools v9.1 from Section C of the OP, https://imgur.com/EC06MJ3 i opened that with administrator MEInfoWin64
@plutomaniac I found this intel me drivers 11.7.0.1057 that are from 2018.
Can u investigate this?
I uploaded to wintrasfer because is 10mb.
-https://we.tl/t-K9OAfEageN
@plutomaniac used ME Analyzer too this is info from it , used bios file
https://imgur.com/a/4fQoFGS
@ jugeljke:
The ME firmware is corrupt. Repairing it is certainly a more difficult procedure as you need to have read/write access to its firmware. You can check by following [Guide] Unlock Intel Flash Descriptor Read/Write Access Permissions for SPI Servicing. Once you have read/write access, youāll need to dump its firmware via Flash Programming Tool command āfptw -d spi.binā and follow [Guide] Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization on that image. Then flash it back via āfptw -f outimage.binā followed by āfptw -gresetā.
@ boombastik:
Mmm yes. They seem to be from the Microsoft Update Catalog. The date is newer and they also include the Intel Capability Licensing Service components which are used for INTEL-SA-00086 mitigation. I think this kit installs the MEI driver and the iCLS which automates the āNotice for CSME v11 INTEL-SA-00086ā that Iāve placed at the OP.
@plutomaniac okey i canāt do this this is really hard for me to understand what am i doing ⦠also i canāt change cpu clock settings in bios⦠something is wrong with this motherboard canāt fix it.
