Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.35.1427
Intel CSME 12.0 Slim PCH-H B,A Firmware v12.0.35.1427
Intel CSME 11.22 Corporate PCH-H B,A Firmware v11.22.65.1590
Intel CSME 11.11 Corporate PCH-H A Firmware v11.11.65.1590
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.65.3590
Intel CSME System Tools v12 r14 - (2019-05-01)
Intel CSME System Tools v11 r22 - (2019-05-01)
So many new firmwares might hint to a series of security vulnerabilities fixed I guess
Intel CSME 12.0 Corporate PCH-LP C Firmware v12.0.35.1427
Intel CSME 11.8 Corporate PCH-LP C Firmware v11.8.65.3590 (YPDM + NPDM)
Intel CSME System Tools v11 r23 - (2019-05-09)
@Plutomaniac
I do use under W10 64bits, without any problem, for a Z390 machine, MEI 1.5 MB Firmware Consumer, the Intel MEI Pack v1915.12.0.1267 which does offer Intel MEI driver v12.0.1247 (dated on 19march19).
Why does this pack is not listed at the start post ?
@ 100PIER:
Because I didnā€™t know about it. I have now updated the OP.
Intel CSME 11.11 Consumer PCH-H A Firmware v11.11.65.1590
Intel CSME System Tools v11 r23 - (2019-05-14)
I am trying to update Intel ME driver on my Aurora R4 with its lastest BIOS (A11).
Current reading shows
Updating Intel ME
After Update
Curious question: How can I save my firmware with its latest IntelME driver for others to make use of?
Intel CSME System Tools v11 r24 - (2019-05-15)
The question does not make sense. The driver is not part of the firmware. Each user can use FWUpdate to update the firmware and manually install the latest driver to their OS.
Got it, because I got confused with ME Analyzer as it requires a firmware file in order for it to report what version of Intel ME it has which got me into thinking that it maybe part of a motherboardā€™s firmware.
It is part of the SPI/BIOS chip of the motherboard. Read Section A at [Guide] Unlock Intel Flash Descriptor Read/Write Access Permissions for SPI Servicing and Section B of this thread. ME Analyzer shows info about the SPI/BIOS image that you input it, not the firmware currently flashed on your system.
EDIT: corrected myself :slight_smile: Got it now :slight_smile: Sorry newb here.
I saw new Intel ME firmware for X299, 11.11.65.1590 version
Itā€™s good for Asus Rampage VI (X299) ?
Thanks
EDIT: itā€™s good
Hi all!
I have some questions if someone can help me.
1. Has anyone tested the update from 11.8.50.3399 -> 11.8.65.3590 on Asus Z170?
11.8.50.3399 - the latest version from the ASUS website (ME update tool)
11.8.65.3590 - the latest version from this forum (Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.65.3590; For 100/200/H310C/B365/Z370-series systems which run CSME Consumer H D,A v11.0 - v11.8). I have read on this forum that there are problems updating Intel ME on some ASUS systems due to their configuration.
2. USB BIOS Flashback revert Intel ME to the existing version in the BIOS file. In the last two BIOS, ASUS did not change the version for Intel ME, it remained 11.6.10.1196
3. Has anyone tested an Intel ME update using the FWUpdate version for EFI64 (FWUpdLcl.efi) or LINUX64 (FWUpdLcl)?
Iā€™ve done updates through Linux a few times on an ASUS Maximus VIII Hero without issues. Currently running 11.8.65.3590.
Thanks thurask. Itā€™s good to know that I can use the Linux version.
@tistou77
Run great Master tistou77 . These firmware protected against DoS descripted by Intel SA-00223 many CVE-2019-XXXX on details here.
https://www.intel.com/content/www/us/en/ā€¦l-sa-00223.html
Already tested on lastest W10 #2020# 1903 Build 18898.1000
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.38.1430
Intel MEI Drivers & Software Consumer DCH v1915.12.0.1259
Intel MEI Drivers & Software Corporate DCH v1915.12.0.1259
Intel CSME 12.0 Corporate PCH-LP C Firmware v12.0.37.1429
Intel CSME System Tools v12 r15 - (2019-05-25)
Hi there,
I have an ASUS dual-socket C602 PCH (X79) motherboard, Asus Z9PA-D8. When I run ME Analyzer, it produces this result. I am confused at what update do I apply on this?
That system is using SPS firmware, not ME. Youā€™ll have to leave it as it is.
