Hm… got Error 8714: Firmware update not initiated due to file open or read failure. I renamed firmware file, so it have short name. CMD was run as admin and i used Win64 version of FWUpdate.
Intel CSME 14.0 Corporate PCH-H A Firmware v14.0.39.1339
Intel CSME 14.0 Corporate PCH-LP B,A Firmware v14.0.39.1339
Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.79.3722
Intel CSME 11.8 Consumer PCH-LP C Firmware v11.8.79.3722
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.78.3681
Intel CSME 11.8 Corporate PCH-LP C Firmware v11.8.78.3681
Intel PCHC CMP PCH-H/LP Firmware v14.0.0.7002
Thank you. As always, you make things too easy for us
All I can suggest is to try redownloading it - maybe the file got corrupted for some reason. Otherwise ask @plutomaniac.
Yeah… maybe something with file. I even made backup of my current ME, just in case something may go wrong and insert it in Analyzer. Look’s O.K. for me, since all fields are same.
But since i got errors, maybe it’s my mistake? Should i do it (update of ME) in DOS? But why there are folders with Windows and Windows64? This is unclear for me. I saw instructions how to do update, but there is nothing about Win or DOS.
And i also saw in BIOS "Me FW Image Re-Flash" field, so i think i need to deal with it too.
I stitching together CSME, PMC and PCHC for a Comet Lake LP system. I used the latest ones available for each and followed the guide detailed in point B. However, the end result seems not to be FWUpdate compatible, ME Analyzer reports FWUpdate Support as “No”. Since the guide explicitly states to ensure it’s “Yes”, what am I doing wrong?
I have received a message when creating the build about Boot Guard being disabled, is it related?
I have uploaded all of the files to this folder in case anyone would like to give them a look: https://mega.nz/folder/ZU8iESCa#OfCxUP8HowwhK1Zuacf0Xg
You haven’t followed the guide properly. You cannot end up with "outimage.bin" if followed correctly, only "FWUpdate.bin". Are you following "How to use CSME v13 - v14 FWUpdate Tool" section?
Indeed! I feel so embarrassed now, click on the green button that builds for FWUpdate, I went and clicked on the green button that read "Build Image" and that was my undoing.
Thank you @plutomaniac ! I wouldn’t have found my mistake otherwise (I tried the process and read the instructions several times, yet didn’t realize I was clicking the wrong button).
EDIT: There’s a warning in the end of the output ME Analizer shows: Note: File size exceeds firmware, unneeded padding! I’ll flash tomorrow though, today is over for me and tomorrow is a work day.
Intel CSME 13.0 Consumer PCH-LP D Firmware v13.0.33.1481
Intel PCHC ICP PCH-H/LP/N Firmware v13.0.0.1005
Intel CSME 13.0 Consumer PCH-LP D Firmware v13.0.35.1508
Intel MEI Drivers & Software v2027.14.0.1684 DCH (Windows 10 >= 1709)
Intel CSME 11.8 Corporate PCH-LP C Firmware v11.8.79.3722
Hi there,
im just trying to install Intel Me for an older pc, but am not having much luck
It is an older PC with a Gigabyte GA-EP45-UD3R which is the Intel P45 chipset
CPU: Core 2 Duo E8400
Win 10 PRO
I have tried running all the MEinfo version that i think would be around its era, but none of thgem work, im guessing because no me software is currently installed?
i think i needed this one "Intel MEI Drivers & Software v5.2.20.1030 (ME 5)" but the link doesnt work
Am i on the right track?
thankyou
There is no ME present in that system
ahhhhh well thats wht i couldnt get anywhere with it lol:)
thankyou plutomaniac!
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.68.1606
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.79.3722
Intel CSME 14.0 Consumer PCH-H A Firmware v14.0.39.1339
Intel CSME 11.12 Corporate PCH-H A Firmware v11.12.79.1722
Hi. Acer TravelMate P215-52. Which latest firmware should be ?
Below is result of MEInfo
BIOS Version V1.16
MEBx Version 0.0.0.0000
GbE Version Unknown
Descriptor Version 1.0
Vendor ID 8086
FW Version 14.0.10.1204 LP Consumer
LMS Version 2026.14.0.1682
MEI Driver Version 2021.14.0.1615
PMC FW Version 140.1.1.1004
PCHC FW Version 14.0.0.7001
PCH Information
PCH Version 0
PCH Device ID 284
PCH Step Data A0
PCH SKU Type Production PRQ Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x31119240
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Persistent RTC and Memory - PRESENT/ENABLED
Capability Licensing Service State Enabled
Crypto HW Support Enabled
End of Manufacturing Enable Yes
FWUpdLcl Enabled
Firmware Update OEM ID 00000000-0000-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Disabled
Intel(R) PTT State Disabled
Intel(R) PTT initial power-up state Disabled
OEM Tag 0x00
PAVP State Yes
Post Manufacturing NVAR Config No
TLS State Disabled
FW Type Production
Last ME reset reason Unknown
BIOS Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
SPI Flash ID 1 C84018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
M3 Autotest Disabled
EPID Group ID 0x355B
Keybox Not Provisioned
RPMC Replay Protection Unsupported
RPMC Replay Protection Bind Counter 0
RPMC Replay Protection Bind Status Pre-bind
RPMC Replay Protection Rebind Unsupported
RPMC Replay Protection Max Rebind 1
Storage Device Type SPI
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 2
Trusted Computing Base SVN 1
Re-key needed False
HW Binding Enabled
FPF UEP ME FW
*In Use
ACM SVN 0x00 0x00 0x00
BSMM SVN 0x00 0x00 0x00
EK Revoke State Not Revoked Not Revoked Not Revoked
Error Enforcement Policy 0 Disabled Disabled Disabled
Error Enforcement Policy 1 Disabled Disabled Disabled
Intel(R) PTT Enabled Enabled Enabled
KM SVN 0x00 0x00 0x00
OEM ID 0x00 0x00 0x00
OEM KM Present Disabled Disabled Disabled
OEM Platform ID 0x00 0x00 0x00
OEM Secure Boot Policy 0x00 0x00 0x00
CPU Debugging Enabled Enabled Enabled
BSP Initialization Enabled Enabled Enabled
Protect BIOS Environment Disabled Disabled Disabled
Measured Boot Disabled Disabled Disabled
Verified Boot Disabled Disabled Disabled
Key Manifest ID 0x00 0x00 0x00
Force Boot Guard ACM Disabled Disabled Disabled
PTT Lockout Override Counter 0x00 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled Enabled
RPMC Rebinding Disabled Disabled Disabled
RPMC Support Disabled Disabled Disabled
SOC Config Lock State Enabled Disabled Enabled
SPI Boot Source Enabled Enabled Enabled
Txt Supported Disabled Disabled Disabled
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
PS C:\Intel CSME System Tools v14.0.11- r1\MEInfo\WIN64>
Searched this website from google. Successfully updated Dell T5610.Thanks for this forum!
Intel CSME 14.0 Consumer PCH-LP B,A Firmware v14.0.39.1339
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.68.1606
Intel CSME 12.0 Corporate PCH-LP C Firmware v12.0.68.1606
