Intel(R) MEInfo Version: 11.0.11.1002 Copyright(C) 2005 - 2016, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version 1.8 MEBx Version 11.0.0.0005 GbE Region does not exist. GbE Version Unknown Vendor ID 8086 PCH Version 21 FW Version 11.0.12.1001 LP LMS Version Not Available MEI Driver Version 11.0.5.1189 Wireless Hardware Version Not Available Wireless Driver Version Not Available
TLS Disabled Last ME reset reason Global system reset Local FWUpdate Enabled BIOS Config Lock Enabled GbE Config Lock Enabled Host Read Access to ME Enabled Host Write Access to ME Enabled Host Read Access to EC Enabled Host Write Access to EC Enabled SPI Flash ID 1 EF4017 SPI Flash ID 2 Unknown BIOS boot State Post Boot OEM ID 00000000-0000-0000-0000-000000000000 Capability Licensing Service Enabled OEM Tag 0x00000000 Slot 1 Board Manufacturer 0x00000000 Slot 2 System Assembler 0x00000000 Slot 3 Reserved 0x00000000 M3 Autotest Disabled C-link Status Enabled Independent Firmware Recovery Disabled EPID Group ID 0xF86 OEM Public Key Hash FPF Not set OEM Public Key Hash ME 0F969281816FA625B5C67109C8029D074CDE27903DC753EDD6FE6E2D14984B20 ACM SVN FPF 0x0 KM SVN FPF 0x0 BSMM SVN FPF 0x0 GuC Encryption Key FPF Not set GuC Encryption Key ME 6DB65FD59FD356F6729140571B5BCD6BB3B83492A16E1BF0A3884442FC3C8A0E
FPF ME --- -- Force Boot Guard ACM Not set Disabled Protect BIOS Environment Not set Disabled CPU Debugging Not set Enabled BSP Initialization Not set Enabled Measured Boot Not set Disabled Verified Boot Not set Disabled Key Manifest ID Not set 0x0 Enforcement Policy Not set 0x0 PTT Not set Enabled EK Revoke State Not Revoked PTT RTC Clear Detection FPF Not set
Thank you a lot for your report. I remember that you have a PCH-LP system and was hoping you would reply with a result. I was thinking of sending a pm and ask manually but you beat me to it. Based on the last two posts, I have removed the Warning from the first post and adjusted the warning text at my reply post above to a toned down note in case someones knows what “PDM” stands for. For now, it seems that it doesn’t matter as far as updating is concerned. Again, thank you for helping out.
Intel(R) Manageability and Security Application code versions:
BIOS Version N1CET43W (1.11 ) MEBx Version 11.0.0.0005 GbE Version 1.3 Vendor ID 8086 PCH Version 21 FW Version 11.0.12.1001 LP LMS Version 11.0.0.1184 MEI Driver Version 11.0.0.1181 Wireless Hardware Version 2.1.77 Wireless Driver Version 18.40.0.9
FW Capabilities 0x7DF65A45
Intel(R) Active Management Technology - PRESENT/DISABLED Intel(R) Capability Licensing Service - PRESENT/ENABLED Protect Audio Video Path - PRESENT/ENABLED Intel(R) Dynamic Application Loader - PRESENT/ENABLED Service Advertisement & Discovery - PRESENT/ENABLED Intel(R) Platform Trust Technology - PRESENT/DISABLED
Intel(R) AMT State Disabled TLS Enabled Last ME reset reason Global system reset Local FWUpdate Password Protected BIOS Config Lock Enabled GbE Config Lock Enabled Host Read Access to ME Disabled Host Write Access to ME Disabled Host Read Access to EC Disabled Host Write Access to EC Disabled SPI Flash ID 1 EF4018 SPI Flash ID 2 Unknown BIOS boot State Post Boot OEM ID 4c656e6f-766f-0000-0000-000000000000 Link Status Link Up System UUID 788ff64c-3058-11b2-XXXX-XXXXXXXXXXXX MAC Address 50-7b-9d-XX-XX-XX IPv4 Address 0.0.0.0 Wireless MAC Address 00-00-00-00-00-00 Wireless IPv4 Address 0.0.0.0 IPv6 Enablement Disabled Wireless IPv6 Enablement Disabled Configuration State Not Started Provisioning Mode PKI Capability Licensing Service Enabled OEM Tag 0x00000000 Slot 1 Board Manufacturer 0x000017AA Slot 2 System Assembler 0x00000000 Slot 3 Reserved 0x00000000 M3 Autotest Enabled C-link Status Enabled Wireless Micro-code Mismatch No Wireless Micro-code ID in Firmware 0x24F3 Wireless LAN in Firmware Intel(R) Dual Band Wireless-AC 8260 Wireless Hardware ID 0x24F3 Wireless LAN Hardware Intel(R) Dual Band Wireless-AC 8260 Localized Language German Independent Firmware Recovery Disabled EPID Group ID 0xFA6 OEM Public Key Hash FPF B81780CA1F680177E08349A29C256B6677XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX OEM Public Key Hash ME 6DD000353945F50D729F0CB6AC151C64F5XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ACM SVN FPF 0x2 KM SVN FPF 0x0 BSMM SVN FPF 0x0 GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000 GuC Encryption Key ME 6DB65FD59FD356F6729140571B5BCD6BB3XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
FPF ME --- -- Force Boot Guard ACM Enabled Enabled Protect BIOS Environment Enabled Enabled CPU Debugging Enabled Enabled BSP Initialization Enabled Enabled Measured Boot Disabled Disabled Verified Boot Enabled Enabled Key Manifest ID 0x1 0x1 Enforcement Policy 0x3 0x3 PTT Enabled Enabled PTT Lockout Override Counter 0x0 EK Revoke State Not Revoked PTT RTC Clear Detection FPF 0x0
Intel(R) MEManuf Version: 11.0.0.1202 Copyright(C) 2005 - 2015, Intel Corporation. All rights reserved.
FW Status Register1: 0x94000245 FW Status Register2: 0x88100106 FW Status Register3: 0xC0000030 FW Status Register4: 0x00084000 FW Status Register5: 0x00001F01 FW Status Register6: 0x44400AC9
CurrentState: Normal ManufacturingMode: Disabled FlashPartition: Valid OperationalState: CM0 with UMA InitComplete: Complete BUPLoadState: Success ErrorCode: No Error ModeOfOperation: Normal SPI Flash Log: Not Present Phase: Maestro ICC: Valid OEM data, ICC programmed ME File System Corrupted: No FPF and ME Config Status: Match
FW Capabilities value is 0x7DF65A45 Feature enablement is 0x5DF25A41 Platform type is 0x42111421 Found an Intel vPro Wireless device Feature enablement is 0x5DF25A41 ME initialization state valid ME operation mode valid Current operation state valid ME error state valid OEM ICC data valid and programmed correctly MFS is not corrupted PCH SKU Emulation is correct FPF and ME Config values matched
Request Intel(R) ME BIST status command... done
Get Intel(R) ME test data command... done
Get Intel(R) ME test data command... done Total of 27 Intel(R) ME test result retrieved
Policy Kernel - Power Package : Live Heap Test - Passed Common Services - LAN : Connectivity to NIC in M3 - Passed Common Services - Wireless LAN : Connectivity to NIC - Passed Policy Kernel - Boot Guard : Self Test - Passed Policy Kernel - Embedded Controller : Power source type - Passed MCA - MCA Tests : Blob - Passed MCA - MCA Tests : MCA Manuf - Passed SMBus - SMBus : Read byte - Passed VDM - General : VDM engine - Passed GFX - General : Sampling engine - Passed USBr - General : Storage - Passed USBr - General : KVM - Passed Common Services - LAN : Connectivity to NIC in M0 - Passed AMT - KVM : Compression engine - Passed AMT - KVM : Compare engine - Passed AMT - EC : Basic connectivity - Passed Policy Kernel - ME Password : Validate MEBx password - Passed Policy Kernel - ME Configuration : M3 Power Rails Available - Passed Policy Kernel - ME Configuration : PROC_MISSING - Passed Common Services - General : WLAN enabled only on mobile or desktop - Passed Policy Kernel - ME Configuration : Wlan Power Well - Passed Common Services - EHBC State : EHBC and Privacy Level states compatibility - Passed Common Services - EHBC State : Valid Embedded Host Based Configuration (EHBC) state - Passed Common Services - Privacy Level : Valid Privacy Level settings - Passed AMT - Power : M3 power rail supported - Passed AMT - Power : Valid WLAN power well (Mobile) - Passed AMT - Power : Valid LAN power well - Passed
Could you please check/verify the archive for "Intel ME System Tools v8.1 r7 - (Updated: 17/11/2015)" → This archive appears to be broken! At least I could not open it using several tools – I also checked one of the other archives and it worked fine, so in general it should work.
Yes I did not take WinRar – but as I said, the other archives (!!from you!!) work fine. I find it hard to believe that this particular archive is broken when using the tools I tested :-/
I opens just fine, I tested it before replying to you for the first time. Not all archives in the first post are RAR5, some smaller in size are RAR2 like INF drivers. Use the latest version of WinRar or 7-zip.
Note: These tools are also compatible with Intel C620 Lewisburg PCH. It is mentioned at the System Tools User Guide that FPT will work with C620 if some BIOS settings are first altered. One of those is called DFX which according to Intel stands for “Design for Manufacturability, Testability and Debuggability”. Once again, according to Intel, the DFx setting can also be called PDM, specifically PDM/DFx. I still don’t know what it means exactly but I suspect that the “PDM” text at the latest 11.0.12.1001 PCH-LP ME firmware has either to do with C620 or some enabled setting on that binary release.
Thanks to this site I was able to update my OLD! MEI Firmware to 7.1.80.1214 but if I read correctly I could go even further and update this to 8.1, any info on how to achieve this?
I have tried FWUpdLcl.exe -F <file> but this fails
Intel(R) MEInfo Version: 7.1.50.1166 Copyright(C) 2005 - 2011, Intel Corporation. All rights reserved.
PMXUtil: Error during PMX Call: PMxDrv!MAPPHYS - Bad Input Parameters GBE Region does not exist. Intel(R) ME code versions:
BIOS Version: R1102T6 MEBx Version: Not available Gbe Version: Unknown VendorID: 8086 PCH Version: 4 FW Version: 7.1.80.1214 UNS Version: Not Available LMS Version: Not Available MEI Driver Version: 11.0.0.1181 Wireless Hardware Version: 0.1.225 Wireless Driver Version: 15.18.0.1
FW Capabilities: 17833024
CPU Upgrade State: Upgrade Capable Cryptography Support: Disabled Last ME reset reason: Power up Local FWUpdate: Enabled BIOS and GbE Config Lock: Unknown Host Read Access to ME: Disabled Host Write Access to ME: Disabled SPI Flash ID #1: EF4016 SPI Flash ID VSCC #1: 20052005 SPI Flash BIOS VSCC: 20052005 BIOS boot State: Post Boot OEM Id: 00000000-0000-0000-0000-000000000000 OEM Tag: 0x00000000
Intel MEI Driver v11.0.11.1193 MEI-Only Installer Intel MEI Drivers & Software v11.0.11.1193 for Corporate systems Intel MEI Drivers & Software v11.0.11.1193 for Consumer systems (Update @ 03/06/2016)
Intel ME 11.0 Corporate PCH-LP Firmware v11.0.12.1003 (Update @ 03/06/2016)
C:\TOOLS\Intel ME System Tools v11.0 r19\MEManuf\WINDOWS64>MEManufWin64 -verbose
Intel(R) MEManuf Version: 11.0.0.1205 Copyright(C) 2005 - 2016, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E000245 FW Status Register2: 0x60002306 FW Status Register3: 0x00000200 FW Status Register4: 0x00004000 FW Status Register5: 0x00000000 FW Status Register6: 0x30000020
CurrentState: Normal ManufacturingMode: Disabled FlashPartition: Valid OperationalState: CM0 with UMA InitComplete: Complete BUPLoadState: Success ErrorCode: No Error ModeOfOperation: Normal SPI Flash Log: Not Present Phase: HOSTCOMM Module ICC: Valid OEM data, ICC programmed ME File System Corrupted: No FPF and ME Config Status: Not committed
FW Capabilities value is 0x40100940 Feature enablement is 0x40100940 Platform type is 0x463F0302 No Intel vPro Wireless device was found Feature enablement is 0x40100940 ME initialization state valid ME operation mode valid Current operation state valid ME error state valid OEM ICC data valid and programmed correctly MFS is not corrupted PCH SKU Emulation is correct
Request Intel(R) ME BIST status command… done
Error 128: Intel(R) test failed to start, error 0x9 returned
Error 117: MEManuf Operation Failed
When using FWUpdLcl.exe -f 9.1.37.1002_1.5MB_PRD_RGN.bin
I get Intel (R) Firmware Update Utility Version: 11.0.0.1205 Copyright (C) 2007 - 2016, Intel Corporation. All rights reserved.
UBU resp. the included ME Analyzer detects the Intel ME Firmware of the BIOS file, which is provided by the mainboard manufacturer. The tool is not able to detect the Intel ME Firmware, which is within the BIOS chip of your system.
I don’t really understand this… Are you saying that there’s no way to apply newer firmware version for MEI? My BIOS shows the latest/newest version of MEI (after I updated it), but UBU MEI Analyzer shows the original (the oldest) version of MEI. Which version do I have exactly then? Or is this because MEI Firmware is updated outside of UBU and thus not included in my latest modded BIOS files? That would make sense, BUT I saved my current BIOS (with the latest MEI Firmware) to a file (I think…).
If MEI Analyzer doesn’t detect the correct firmware version, then what is the purpose of it? Is there a way to make it detect the correct version?
@MonarchX “MEA -info” will Display the current Version of ME Firmware that is currently running on your PC. You can get the latest ME Analyzer here The Ubu MEA detects the ME Version inside the bios-file you opened with Ubu!
If your Motherboard bios displays the latest version as you said, everything is fine
No, but you have to flash the Intel ME Firmware separately. The Intel ME Analyzer of the UBU tool just shows the Intel ME version of the BIOS file, which it just has opened, but is unabe to update it. This procedure has to be done separately. The UEFI BIOS Updater just updates the modules, which belong to the BIOS Region of the BIOS file. The other parts of the BIOS incl. the ME Region stays untouched.
The Intel ME Analyzer does detect the correct Intel ME Firmware version of any UEFI BIOS, which has been opened by the tool. The purpose of the ME Analyzer as part of the UBU tool is, that the user can easily realize, whether the latest BIOS, which has been delivered by the mainboard manufacturer, contains a newer Intel ME Firmware version than the Intel ME Region has, which is currently working within the user’s mainboard BIOS chip. If the user wants to get the newer Intel ME Firmware, he has to flash it separately by using a special Intel ME Firmware Update tool.
