Then check the Engine Firmware Repositories thread, don’t dump constantly everywhere
Before on 11.0.12.1008:
(c) 2015 Microsoft Corporation. All rights reserved.
c:\MEInfo\WINDOWS64>meinfowin64 -verbose
Intel(R) MEInfo Version: 11.0.11.1002
Copyright(C) 2005 - 2016, Intel Corporation. All rights reserved.
FW Status Register1: 0x90000245
FW Status Register2: 0x00F60506
FW Status Register3: 0x00000020
FW Status Register4: 0x00084000
FW Status Register5: 0x00000000
FW Status Register6: 0xC0000000
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
Phase: ROM/Preboot
ICC: Valid OEM data, ICC programmed
ME File System Corrupted: No
PhaseStatus: AFTER_SRAM_INIT
FPF and ME Config Status: No match
FW Capabilities value is 0x31111D40
Feature enablement is 0x11111940
Platform type is 0x71220322
No Intel vPro Wireless device was found
Intel(R) ME code versions:
Windows OS Version : 6.2.9200 “”
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
BIOS Version 1701
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 22 (0x 16 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 10 ( 0x 0A ) found, size of 6 (0x 06 ) bytes
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 12 ( 0x 0C ) found, size of 5 (0x 05 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 34 ( 0x 22 ) found, size of 11 (0x 0B ) bytes
Table Type 26 ( 0x 1A ) found, size of 22 (0x 16 ) bytes
Table Type 36 ( 0x 24 ) found, size of 16 (0x 10 ) bytes
Table Type 35 ( 0x 23 ) found, size of 11 (0x 0B ) bytes
Table Type 28 ( 0x 1C ) found, size of 22 (0x 16 ) bytes
Table Type 27 ( 0x 1B ) found, size of 15 (0x 0F ) bytes
Table Type 29 ( 0x 1D ) found, size of 22 (0x 16 ) bytes
Table Type 39 ( 0x 27 ) found, size of 22 (0x 16 ) bytes
Table Type 40 ( 0x 28 ) found, size of 32 (0x 20 ) bytes
Table Type 41 ( 0x 29 ) found, size of 11 (0x 0B ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 4 ( 0x 04 ) found, size of 48 (0x 30 ) bytes
Table Type 16 ( 0x 10 ) found, size of 23 (0x 17 ) bytes
Table Type 17 ( 0x 11 ) found, size of 40 (0x 28 ) bytes
Table Type 19 ( 0x 13 ) found, size of 31 (0x 1F ) bytes
Table Type 221 ( 0x DD ) found, size of 12 (0x 0C ) bytes
Table Type 20 ( 0x 14 ) found, size of 35 (0x 23 ) bytes
Table Type 130 ( 0x 82 ) found, size of 20 (0x 14 ) bytes
Table Type 131 ( 0x 83 ) found, size of 64 (0x 40 ) bytes
MEBx Version found is 0.0.0.0000
MEBx Version 0.0.0.0000
GbE Version 0.7
Vendor ID 8086
PCH Version 31
FW Version 11.0.12.1008 H
LMS Version Not Available
MEI Driver Version 11.5.0.1011
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
FW Capabilities 0x31111D40
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) NFC Capabilities - NOT PRESENT
Intel(R) Platform Trust Technology - PRESENT/DISABLED
TLS Disabled
Last ME reset reason Power up
Local FWUpdate Enabled
BIOS Config Lock Disabled
GbE Config Lock Disabled
Get flash master region access status…done
Host Read Access to ME Disabled
Host Write Access to ME Disabled
Get EC region access status…done
Host Read Access to EC Disabled
Host Write Access to EC Disabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 EF4018
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
Independent Firmware Recovery Disabled
EPID Group ID 0xF86
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
Retrieving Variable "OEM Public Key Hash"
OEM Public Key Hash ME 66687AADF862BD776C8FC18B8E9F8E20089714856EE233B3902A591D0D5F2925
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
Retrieving Variable "GuC Encryption Key"
GuC Encryption Key ME 6DB65FD59FD356F6729140571B5BCD6BB3B83492A16E1BF0A3884442FC3C8A0E
FPF ME
Force Boot Guard ACM Disabled
Retrieving Variable “Force Boot Guard ACM Enabled”
Disabled
Protect BIOS Environment Disabled
Retrieving Variable “Protect BIOS Environment Enabled”
Disabled
CPU Debugging Enabled
Retrieving Variable “CPU Debugging”
Enabled
BSP Initialization Enabled
Retrieving Variable “BSP Initialization”
Enabled
Measured Boot Disabled
Retrieving Variable “Measured Boot Enabled”
Disabled
Verified Boot Disabled
Retrieving Variable “Verified Boot Enabled”
Disabled
Key Manifest ID 0x0
Retrieving Variable “Key Manifest ID”
0x0
Enforcement Policy 0x0
Retrieving Variable “Error Enforcement Policy”
0x0
PTT Disabled
Retrieving Variable “Intel(R) PTT Supported”
Enabled
PTT Lockout Override Counter 0x0
EK Revoke State Not Revoked
PTT RTC Clear Detection FPF 0x0
After 11.0.15.1003:
FW Status Register2: 0x060B0506
FW Status Register3: 0x00000420
ErrorCode: No Error
Phase: ROM/Preboot
PhaseStatus: CALL_NEXT_MODULE
BIOS Version 1701
GbE Version 0.7
Vendor ID 8086
PCH Version 31
FW Version 11.0.15.1003 H
TLS Disabled
Last ME reset reason Firmware reset
OEM Tag 0x00000000
EPID Group ID 0xF86
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
FPF ME
Disabled
Disabled
Enabled
Enabled
Disabled
Disabled
Key Manifest ID 0x0
0x0
0x0
PTT Disabled
Enabled
Not sure if this helps you in any way since Pacman already confirmed that FW status Register3 value after flash is 0x00000420. FW status Register2 value changes from 0x00F60506 (11.0.12.1008) to 0x060B0506 (11.0.15.1003) but no idea if that means anything.
Z170 DELUXE FW 11.0.15.1003
FW Status Register2: 0x06F60506
ErrorCode: No Error
Phase: ROM/Preboot
BIOS Version 1801
GbE Version 0.7
Vendor ID 8086
PCH Version 31
MEI Driver Version 11.0.5.1189
TLS Disabled
OEM Tag 0x00000000
EPID Group ID 0xF88
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
FPF ME
Disabled
Disabled
Enabled
Enabled
Disabled
Disabled
Key Manifest ID 0x0
0x0
0x0
PTT Disabled
Enabled
@plutomaniac MEI Driver update 11.5.0.1015 at station-drivers: http://www.station-drivers.com/index.php…id=2327&lang=fr
hi,the 8.0.4.1441_5MB_PRE_RGNis good?
This new Intel MEI driver is running fine with my Z97 system.
Here are the related pictures after having run the MEInfo and MEManuf tools:
@Fernando i ran the ME Analyzer v1.57, it shown;
Engine Driver: 11.5.0.1011
Engine Firmware: 9.1.25.1005
i’m using ASRock H97 Pro4
which one suitable for me? 11.0.5.1189 or 11.5.0.10.11 or newer? what bout the engine firmware version? thanks.
The latest Intel ME Firmware for your system is v9.1.37.1002
You should better ask plutomaniac. He knows much more about this topic than me.
@Fernando thanks but he’s offline. where should i put the .bin firmware so that i can flash it?
i ran FWUpdLcl -f ME.BIN but it shown invalid file/usage . i changed the .bin file to ME.bin & put inside FWUpdate > Local-Win >
Please wait until he is online again. There is no reason to be in a hurry regarding your questions.
I have a rather strange issue, my motherboard is a Gigabyte GA-H110N and when I goto their drivers page here http://www.gigabyte.com/products/product…spx?pid=5738#ov I discover their download of the Intel Management Engine Interface driver is the 5M version. I’m very confused because this appears to be a Consumer board not Corporate, why then do they link to the 5M version? It leaves me lost as to what firmware I should flash the 5M or 1.5M? MEInfo doesn’t seem to make a determination of which to use.
@Fernando IME Update failed
i tried use Corporate Systems (5 MB) then it works! previously i’m using Consumer Systems (1.5 MB)
previous FW: 9.1.25.1005 & i made a backup too.
MEI: 11.5.0.1011
FW: 9.1.37.1002
MEManuf Test Passed too.
FYI, just try both & it will only work on either one for sure. i just tested for my ASRock H97 Pro4 (ATX)
@crystalorb :
Welcome at Win-RAID Forum!
There is a big difference between 1.5M and 5M systems regarding the Intel ME Firmware and Software, but not regarding the Intel ME driver. Both platforms are using the exactly same Intel ME driver.
Regards
Dieter (alias Fernando)
How do you know if the firmware is 5M? Or is it basic that it’s 1.5M unless it’s stated otherwise?
An Intel ME Firmware file (*.bin) for the 5M platform is much bigger sized than the 1.5M Firmware file.
Sorry, which of the 2 files did you use? Thanks!
11.0.15.1003…FWU.bin
