Intel CPU Microcode modules for 8-Series Chipsets
That would be much appreciated by the Forum visitors. Please write your guide directly into >this< Sub-Forum and give the thread a meaningful title like "[Guide] How to manually update the Intel CPU Microcode".
You should put all these files into 1 single *.ZIP or *.RAR archive and attach it to your guide.
According to UBU tool 1.65 > This MSI 7A69_223.zip Download < has found new CPU microcode
Select option for update
1 - Intel RST(e) OROM and EFI SataDriver
OROM IRST RAID for SATA - 15.5.0.2813
EFI IRST RAID for SATA - 15.5.0.2813
EFI AMI NVME Driver present
2 - Intel OROM VBIOS and EFI GOP Driver
OROM VBIOS SKL-KBL - 1046
EFI GOP Driver SKL-KBL - 9.0.1052
3 - LAN OROM PXE and EFI UNDI - Intel, RTK, BCM, QCA
OROM Intel Boot Agent CL - 0.1.10
EFI Intel Gigabit UNDI - 0.0.09
7 - Update Intel CPU MicroCode
Kabylake CPUID 0906E9 - 48
Skylake CPUID 0506E3 - A6
Found new Microcode 000906E9000000220000004811152016000178004761D4C9
9 - ME Analyzer
FW ME of scanned BIOS File 11.6.25.1229 CON_H_D0
i - Versions, HomePages and etc.
0 - Exit
Press ENTER - Re-Scanning ALL EFI modules.
Enter number:
Hey.
I updated the microcode in BIOS 1A (Haswell).
AIDA indicate 1E.
0326C31D.rar (21.1 KB)
latest microcode haswell
0326C31E.rar (21.1 KB)
Perfect! Thanks! I also have a Haswell CPU :slight_smile:
Latest microcode for Haswell is : cpu000306C3_plat32_ver00000021_date#10-05-2016
Available from UBU package.
Hi Fernando, I am looking to add microcode for the Intel Xeon W3680 into the latest bios for two Gigabyte motherboards GA-EX58-UD5, and GA-EX58-UD4P. Both have support for the W3690, but not the W3680 so I can replace if there isn’t space to add. Is there an appropriate tool and source for the appropriate microcode files somewhere in your forum? If I am in the wrong place, can you give me a pointer?
Thanks!
David
@David359 :
Since I am not an expert regarding how to update/customize the CPU microcode, I cannot really help you.
Why don’t you try it by using the UBU tool (after having added the required AMI Aptio V MMTool)?
@David359 & @Fernando
You’ve got no UEFI-BIOS, so there no chance to use UBU tool.
Both are Award Dual-BIOS. There is no special tool to do the changes. I do it with HxD.
When you look @ Intel website of W3680, then you’ll find the actual Linux CPU MC Database.
Then you need program ‘microdecode.exe microcode.dat’ to decompress the MCs from linux-db.
After c’n’p the microcodes you’ll have to create the new checksum for the whole BIOS-file with CBROM.
If you want to update some option-ROMs, then do it with CBROM like in this tutorial.
I can do it for you, if you don’t wanna find out, how-to-do. If I should do so, give me please the BIOSes.
I’ve done it succesfully with two BIOS of S.775 Gigabyte mainboard in the last week.
I’m owning a Xeon E5450 S.771 and putted it with a special adapter in the S.775 board.
Best regards, MiMo
Anyone know by chance what the latest Kaby Lake microcode is.
LGA 1151?
or X299?
1151 is cpu000506E3_plat36_ver000000BA_date09-04-2017
Latest Kabylake is cpu000906E9_plat2A_ver00000070_date09-08-2017; latest Skylake is cpu000506E3_plat36_ver000000BE_date2017-08-20
Are there any public or non public changelogs or at least some vague Information about it?
