Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 11.8 Corporate PCH-LP C Firmware v11.8.60.3561 (NPDM + YPDM)
Note: ME Analyzer v1.82.2 or newer is required to properly detect the PDM status of the above firmware.
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.24.1314
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.24.1314
thanks
I need help please on z390 for Update the ME. I have download the latest Firmware and there a many Tools now. How flash it now? I have H Consumer.
Read the first post on how to update Engine firmware, everything you need is there.
No. Since it’s obvious he has better equipment than you, that means he is better than you, remember that.
Now, you’re going to take your time and formulate a very specific, step-by-step procedure just for him, understood?
Good, get to it.
I thought that someone can’t update 1.5 firmware to 5. Is this possible?
Intel MEI Driver v1908.12.0.1231 MEI-Only Installer
Intel MEI Driver v1904.12.0.1208 (Windows 8 & Windows 10) INF for manual installation
Intel MEI Driver v1904.12.0.1208 (Windows 7) INF for manual installation
Generally no. There are some chipsets which can support both Consumer/1.5MB and Corporate/5MB firmware (check Intel PCH documentation) but it requires different BIOS code as well and it certainly cannot happen via FWUpdate tool.
Something very strange happened to me. I noticed that my board, at full load used to make a noise, like a bzzzzz but as they come they dissapear. This weekend, doing some OS installs to find the best AHCI drivers, I noticed that MEI Device has gonne. I’ve tryed everything at Bios and with installers drivers but the device has definitively gonne. I thought that the noise bzzzz was the MEI Chip burning away.
Any advice to me ?
PS. I already tryed Gigabyte support and Im waiting his answer.
It’s definitely not some chip burning. The Engine co-processor is within the PCH so if that died you would have other major issues as well. You are probably hearing coil whine from some component but that’s not dangerous, only annoying. Run MEInfo tool with β€œ-verbose” parameter and then with β€œ-fwsts” parameter and show us the results.
Thanks for the answer @plutomaniac !
When I get at home I will try these commands and post result here… thank about coil wine… it’s strange because I have my PC for about 5 years and never happen…these days these sound appear and MEI gonne…really weird.
My Computer -
GA-B75M-D3H, Xeon E3 1280 v2, 16 Gb Ram 1600 CL9, GTX 1060 6Gb (before was an GTX 960 and never got this sound), SSD Kingston 120 Gb, SSD Samsung 860 Evo 500 Gb, Seagate 1 Tb, Power Supply CoolerMaster 80plus 550w
PS. It only happen at full load, like 3dMark, Cinebench, Vray bench… normal use and games doesnt happen
It could be related since the Engine does control system clocks and power management so, if its firmware is corrupt, it could be that some power options are not working optimally causing the coil while side-effect.
this not help me @plutomaniac. I have read but my english is not so good. Arrogant answers can therefore be avoided. Latest v12 is intel_me_fw_12.0.30.1408_con_h(www.station-drivers.com). Whene i check this i get this message with ME Analyzer: File size exceeds firmware, unneeded padding! The file on station driver is compiled, dont need Flash Image Tool.
Hi.
I did the commands on my computer and got these values. I made an text file attached. I have a video with the supposed coil but the sound is different to me… I can upload if you want to check.
Thank you again
MEInfo.txt (6.49 KB)
Yes the ME is not working properly. It’s probably corrupted. Run Flash Programming Tool with β€œ-greset” parameter to see if that helps at all. If not, you’ll need to re-flash the ME firmware which requires read/write access to the ME region of the SPI/BIOS chip, meaning an unlocked Flash Descriptor as explained at [Guide] Unlock Intel Flash Descriptor Read/Write Access Permissions for SPI Servicing. It’s a 7-series Gigabyte board so there is a very high chance that the FD is already unlocked as it was back then, speaking from personal experience. There should also exist a Backup BIOS chip and I think you can initiate a recovery process which copies the Backup to Main. But if the FD is unlocked on the Main, there is no need to mess with the Backup chip.
No need. Let’s fix the ME firmware first and who knows, that side effect might go away.
Hi @plutomaniac ! I’ve tried your first tip but I got no success, FWtool didn’t recognize my chip or ME FW and stopped, before going to second procedure I was thinking if ME is on Bios region, maybe…if I got lucky, I could rewrite my Bios and with that repair it, but with a simples Bios update probably I will not get it, so I’ve tried Bios Recovery of MB, holded power button for about 3 seconds and a half ( just before it poweroff again) from a startup and the process of Backup started…and after system boot up… tΓ£n tΓ£n tΓ£n tΓ£n… Intel ME was there and operational. Thank you for your help and to give me a light of hope.
Now a second question… using MEInfo I noticed I upgraded it with a 1.5Mb FW… I did the upgrade november 2018… there is a chance that I upgrade with a wrong FW ? Should my system be the 5Mb corporate ?
Edit: I extracted my current FW with FW tool and check it with MEA and it say it’s 5Mb. but its an old version and vunerable to SA-000086. I’m affraid to update again and it get corrupted again.
PS. I dont have more coil whine. I remember it began to do sounds after I update it, did I something wrong ?
MEInfo 2.txt (9.88 KB)
MEA.txt (1.24 KB)
The SPI/BIOS image from Gigabyte includes 5MB firmware so you must update to that only. You can apply the latest from this thread which also covers SA-00086. There shouldn’t be any problems but then again, you can recover very easily no matter what. Not hearing the coil whine is a good thing of course and it indeed had to do with power management issues while the ME was not operational.
Intel CSME 11.8 Consumer PCH-LP C Firmware v11.8.60.3561 (NPDM + YPDM)
Note: ME Analyzer v1.82.3 or newer is required to properly detect the PDM status of the above firmware.
Hi! I’ve been catching up with the whole affair today looking to bring a system I have up to date.
Although it was several months ago I read you wanted some info on systems shipping with CSME 12, so here there are some outputs (MEI Analyzer comes in another post because of the character limit :S):
MEInfoWin64.exe -verbose:
Intel (R) MEInfo Version: 12.0.22.1310
Copyright (C) 2005 - 2018, Intel Corporation. All rights reserved.
LPC Device Id: 9D84.
Platform: Cannonlake Platform
Windows OS Version : 10.0
FW Status Register1: 0xA4000255
FW Status Register2: 0x860B0106
FW Status Register3: 0x00000020
FW Status Register4: 0x00004004
FW Status Register5: 0x00001F01
FW Status Register6: 0x07C00BC9
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Present
Phase: Maestro
ME File System Corrupted: No
PhaseStatus: UNKNOWN
FPF and ME Config Status: Not committed
FW Capabilities value is 0x31109240
Feature enablement is 0x31109240
Platform type is 0x41000391
Intel(R) ME code versions:
Table Type 255 ( 0x FF ) found, size of 0 (0x 00 ) bytes
BIOS Version 1.3.0
Table Type 0 ( 0x 00 ) found, size of 54 (0x 36 ) bytes
Table Type 1 ( 0x 01 ) found, size of 74 (0x 4A ) bytes
Table Type 2 ( 0x 02 ) found, size of 62 (0x 3E ) bytes
Table Type 3 ( 0x 03 ) found, size of 50 (0x 32 ) bytes
Table Type 8 ( 0x 08 ) found, size of 25 (0x 19 ) bytes
Table Type 9 ( 0x 09 ) found, size of 23 (0x 17 ) bytes
Table Type 10 ( 0x 0A ) found, size of 27 (0x 1B ) bytes
Table Type 11 ( 0x 0B ) found, size of 79 (0x 4F ) bytes
Table Type 12 ( 0x 0C ) found, size of 21 (0x 15 ) bytes
Table Type 15 ( 0x 0F ) found, size of 37 (0x 25 ) bytes
Table Type 21 ( 0x 15 ) found, size of 9 (0x 09 ) bytes
Table Type 25 ( 0x 19 ) found, size of 11 (0x 0B ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 34 ( 0x 22 ) found, size of 19 (0x 13 ) bytes
Table Type 36 ( 0x 24 ) found, size of 18 (0x 12 ) bytes
Table Type 35 ( 0x 23 ) found, size of 27 (0x 1B ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 66 (0x 42 ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 205 ( 0x CD ) found, size of 24 (0x 18 ) bytes
Table Type 205 ( 0x CD ) found, size of 93 (0x 5D ) bytes
Table Type 205 ( 0x CD ) found, size of 388 (0x 184 ) bytes
Table Type 205 ( 0x CD ) found, size of 208 (0x D0 ) bytes
Table Type 7 ( 0x 07 ) found, size of 37 (0x 25 ) bytes
Table Type 4 ( 0x 04 ) found, size of 185 (0x B9 ) bytes
Table Type 20 ( 0x 14 ) found, size of 37 (0x 25 ) bytes
Table Type 126 ( 0x 7E ) found, size of 57 (0x 39 ) bytes
Table Type 22 ( 0x 16 ) found, size of 121 (0x 79 ) bytes
Table Type 27 ( 0x 1B ) found, size of 24 (0x 18 ) bytes
Table Type 28 ( 0x 1C ) found, size of 35 (0x 23 ) bytes
Table Type 177 ( 0x B1 ) found, size of 14 (0x 0E ) bytes
Table Type 178 ( 0x B2 ) found, size of 126 (0x 7E ) bytes
Table Type 208 ( 0x D0 ) found, size of 35 (0x 23 ) bytes
Table Type 216 ( 0x D8 ) found, size of 31 (0x 1F ) bytes
Table Type 217 ( 0x D9 ) found, size of 28 (0x 1C ) bytes
Table Type 218 ( 0x DA ) found, size of 253 (0x FD ) bytes
Table Type 218 ( 0x DA ) found, size of 187 (0x BB ) bytes
Table Type 220 ( 0x DC ) found, size of 24 (0x 18 ) bytes
Table Type 221 ( 0x DD ) found, size of 21 (0x 15 ) bytes
Table Type 222 ( 0x DE ) found, size of 18 (0x 12 ) bytes
Table Type 218 ( 0x DA ) found, size of 79 (0x 4F ) bytes
MEBx Version 0.0.0.0000
GbE Version Unknown
Descriptor Version 1.0
Vendor ID 8086
FW Version 12.0.5.1117 LP Consumer
LMS Version 1846.12.0.1173
MEI Driver Version 1904.12.0.1208
PMC FW Version 300.1.20.1016
OEM FW Version 0.0.0.0000
PCH Information
PCH Version 30
PCH Device ID 9D84
PCH Step Data D0
PCH SKU Type Production Pre-QS Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x31109240
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) Platform Trust Technology - PRESENT/ENABLED
Persistent RTC and Memory - PRESENT/ENABLED
Capability Licensing Service Enabled
End of Manufacturing Enable No
Local FWUpdate Enabled
OEM ID 00000000-0000-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Disabled
Intel(R) PTT Supported Yes
Intel(R) PTT initial power-up state Enabled
OEM Tag 0x00
PAVP Supported Yes
Post Manufacturing NVAR Config Enabled Yes
TLS Disabled
FW Type Production
Last ME reset reason Unknown
BIOS Config Lock Enabled
GbE Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Enabled
Host Read Access to EC Enabled
Host Write Access to EC Enabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 C22018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
Slot 1 Board Manufacturer 0x00001028
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 3
Trusted Computing Base SVN 0
Re-key needed False
HW Binding Enabled
FPF UEP ME FW
*In Use
β€” β€” -----
Enforcement Policy Not set 0x03 0x03
EK Revoke State Not set Not Revoke Not Revoke # Not Revoke=0, Revoke=1
PTT Not set Enabled Enabled # Disabled=0, Enabled=1
OEM ID Not set 0x00 0x00
OEM Key Manifest Present Not set Present Present # Not Present=0, Present=1
OEM Platform ID Not set 0x00 0x00
OEM Secure Boot Policy Not set 0x3F9 0x3F9
CPU Debugging Not set Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Not set Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Not set Enabled Enabled # Disabled=0, Enabled=1
Measured Boot Not set Enabled Enabled # Disabled=0, Enabled=1
Verified Boot Not set Enabled Enabled # Disabled=0, Enabled=1
Key Manifest ID Not set 0x0F 0x0F
Persistent PRTC Backup Power Not set Enabled Enabled # Enabled=0, Disabled=1
RPMB Migration Done Not set Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock Not set Not Done Not Done # Not Done=0, Done=1
SPI Boot Source Not set Enabled Enabled # Enabled=0, Disabled=1
TXT Supported Not set Disabled Disabled # Disabled=0, Enabled=1
ACM SVN FPF Not set
BSMM SVN FPF Not set
KM SVN FPF Not set
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP 2A384C46A3E4442377D736FD5E2B91E7E8C9C0175D74A3A9A2463BB5023C9F57
OEM Public Key Hash ME FW 2A384C46A3E4442377D736FD5E2B91E7E8C9C0175D74A3A9A2463BB5023C9F57
PTT Lockout Override Counter FPF Not set
cctWin.exe gcc (No PCH stepping data, as expected I guess):
Intel (R) Clock Commander Tool Version: 12.0.22.1310
Copyright (C) 2009 - 2018 Intel Corporation. All rights reserved.
HW Product Family:CNP-LP
FW Version Major: 12
FW Version Minor: 0
FW Version Hotfix: 5
FW Version Build: 1117
ICC HW SKU = ENHANCED
HECI CMD Status = 0x00000000 (SUCCESS)
MEManufWin64.exe -verbose (probably uninteresting though):
Intel (R) MEManuf Version: 12.0.22.1310
ErrorCode: No Error
Phase: Maestro
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
MFS is not corrupted
PCH SKU Emulation is correct
MEManuf NextReboot option can only run when M3 Autotest is Enabled.
done
Get Intel(R) ME test data command… done
Total of 4 Intel(R) ME test result retrieved
Policy Kernel - Boot Guard : Self Test - Passed
VDM - General : VDM engine - Passed
PAVP - General : Set Edp Port - Passed
Policy Kernel - ME Configuration : PROC_MISSING - Passed
Clear Intel(R) ME test data command… done
MEManuf Operation Passed
I see things have changed and a PMC firmware has to be stitched to the CSME one in order to use FWUpdate, easy thing to do in FIT with the details in the first post. Some other posts also explained that the rest of the configuration in FIT is not relevant for a firmware upgrade through FWUpdate, which was a doubt I had, when opening the ME section of the BIOS update file in FIT there were several settings that differed from the default.
But I wonder if the chipset stepping could be troubling, the official MEI info tool reports it as D0 but MEI Analyzer shows C (and there’s no D0 firmware I could see… do they even refer to the same thing?). I was planning on using 12.0.23.1311_CON_LP_C_PRD_EXTR and CNP_300.1.20.1023_LP_C_PRD (the current latest) until I noticed that.
It’s a newish machine (an Inspiron 7580) so it’s bound to have more BIOS updates. The currently provided ME VCN for this model is at 9 and the latest at 14, FWUpdate prevents SVN and VCN rollbacks, but does anybody know if such restriction also applies to the way Dell BIOS updates are performed? Given that the BIOS update from January has an ME firmware from last June… chances are a new BIOS update would contain an ME firmware that violates that restriction.
That’s about it! Thanks for all the useful and detailed info compiled over the years by the way!
ME Analyzer 1.82.2 (-ver86, input being a dump of the running ME via FPTW64.exe -me -d me.bin):
β•‘ ME Analyzer v1.82.2 r153 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ MFS 002 Anti-Replay Integrity β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ HMAC MD5 β”‚ redacted (seemed sensitive :P) β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Flags Unknown 0 β”‚ 0b β•‘
β•‘ Anti-Replay Protection β”‚ No β•‘
β•‘ Flags Unknown 1 β”‚ 0b β•‘
β•‘ Encryption Protection β”‚ Yes β•‘
β•‘ Flags Unknown 2 β”‚ 0100111b β•‘
β•‘ Anti-Replay Index β”‚ 0 β•‘
β•‘ Flags Unknown 3 β”‚ 0b β•‘
β•‘ Security Version Number β”‚ 1 β•‘
β•‘ Flags Unknown 4 β”‚ 00b β•‘
β•‘ Anti-Replay Random Value β”‚ 0x00000000 β•‘
β•‘ Anti-Replay Counter Value β”‚ 0x00000000 β•‘
β•‘ Unknown β”‚ 0x7E62D1A6C6EDAFF7E4AF2ED4 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ MFS 003 Anti-Replay Integrity β•‘
β•‘ Unknown β”‚ 0x8C47D4135D767E7449019674 β•‘
β•‘ MFS 004 SVN Migration Integrity β•‘
β•‘ Unknown β”‚ 0x5F4E542839BCD3D3DA6EDAA5 β•‘
β•‘ MFS 005 Quota Storage Integrity β•‘
β•‘ Encryption Protection β”‚ No β•‘
β•‘ Flags Unknown 2 β”‚ 0010111b β•‘
β•‘ Security Version Number β”‚ 0 β•‘
β•‘ Unknown β”‚ 0xF1449892177F604737BF5670 β•‘
β•‘ me.bin (1/1) β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Family β”‚ CSE ME β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 12.0.5.1117 β•‘
β•‘ Release β”‚ Production β•‘
β•‘ Type β”‚ Region, Extracted β•‘
β•‘ SKU β”‚ Consumer LP β•‘
β•‘ Chipset β”‚ CNP-LP C β•‘
β•‘ Version Control Number β”‚ 9 β•‘
β•‘ Production Version β”‚ Yes β•‘
β•‘ OEM RSA Signature β”‚ Yes β•‘
β•‘ OEM Unlock Token β”‚ No β•‘
β•‘ FWUpdate Support β”‚ No β•‘
β•‘ Date β”‚ 2018-06-21 β•‘
β•‘ File System State β”‚ Initialized β•‘
β•‘ Size β”‚ 0x27A000 β•‘
β•‘ Flash Image Tool β”‚ 12.0.5.1117 β•‘
β•‘ Latest β”‚ No β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ Power Management Controller β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Family β”‚ PMC β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 300.1.20.1016 β•‘
β•‘ Type β”‚ Independent β•‘
β•‘ Chipset SKU β”‚ LP β•‘
β•‘ Chipset Stepping β”‚ C β•‘
β•‘ Security Version Number β”‚ 2 β•‘
β•‘ Date β”‚ 2018-07-02 β•‘
β•‘ Size β”‚ 0x11000 β•‘
β•‘ Chipset Support β”‚ CNP β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
Note: File size exceeds firmware, unneeded padding!
ME Analyzer 1.82.2 (-ver86, input being the ME section extracted from the current BIOS update):
β•‘ section_2_12.0.5.1117.data (1/1) β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ OEM RSA Signature β”‚ No β•‘
β•‘ FWUpdate Support β”‚ Yes β•‘
β•‘ File System State β”‚ Configured β•‘
β•‘ Size β”‚ 0x276000 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
