Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Hi KaoDome, that’s a pretty deep dive you’ve made there. Even checked the File System out, very impressive.
Indeed they have. That’s why I was asking for those logs back then. They are no longer needed as I have sorted out how to distinguish the chipset steppings for each firmware now but it’s always good to have them here for future reference.
Exactly, OEM FIT configuration (MFS File 7) is useless for FWUpdate use. Only the stock/static Intel configuration (MFS File 6) is needed. The rest of the MFS Files (1-5, 8+) are present at Initialized/dumped firmware so that’s why you saw them. These can be removed by following [Guide] Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization.
Ha, interesting thought but it is not actually that sensitive. Each Chipset has its own key but HMAC is used for integrity and combines the hash of said key with a secret Intel private key which is known only to them. Since you cannot reverse a hash (MD5 in this case) to get the original content and the Intel private key is safeguarded, there is nothing to fear from those HMACs.
Yes I have noticed that as well. It is Intel being weird as far as I can tell. I have seen CNP-LP systems which report at MEInfo C, others D and even some A (probably a MEInfo bug at older versions). Both CNP-LP C and CNP-LP D are the same firmware-wise. MEA detects them as CNP-LP C because that’s what the firmware reports so go figure… Basically, for all released/Production CNP-LP systems, users need PCH-LP C firmware. One small exception is that one (literally one) Lenovo 330-15ICN laptop (stepping B) which was released very early so that Intel could say/reassure that “hey, we managed to release 1 Cannon Lake CPU in 2018”. Cannon Lake is dead now so we know how that turned out.
Yes it does. The Dell Updater basically uses a lite FWUpdate EFI variant called “FWUpdate Reduced Size (RS)” so it fully respects the FD locks and the SVN/VCN/PV-bit restrictions of CSME and PMC firmware upgrades/downgrades.
Technically yes. I think the Dell Updater automatically skips updating the Engine firmware when it detects that it is newer so it should continue to update the BIOS, EC or whatever else it wants to. I agree with you though, you can wait for Dell to release newer firmware and avoid any potential issues, even if nothing like that has been reported here, if I remember properly. Dell is generally decent to good when it comes to Engine firwmware updates so yeah you can wait for them.
Thank you for your kind words, much appreciated. All this wouldn’t be possible without members such as you.
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.32.1420
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.65.3572
Greetings! I know this is a stupid question but I can’t seem to find the answer anywhere, so please be patient with me :slight_smile:
I’m thinking about updating the ME firmware on my laptop I fount out that it need Consumer PCH-LP 11.8 (it has 11.5 currently), but I can’t seem to figure out if I need the PDM or NOPDM version.
Thanks in advance!
What laptop is that exactly? We cannot guess it. From Intel CSME System Tools v11, run FWUpdate tool with parameter “-save upd.bin”. Once it’s done, drop “upd.bin” file into ME Analyzer and check the “Power Down Mitigation” status.
It is an Acer laptop running H2O bios if I remember correctly. Here is the screenshot of the current Intel ME firmware, and the two other I found might be the correct version. The middle one is the NOPDM one (if I’m right).
ME-FW_12.0.31.1416+PMC_300.2.11.1020
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
Intel (R) MEInfo Version: 12.0.22.1310
Copyright (C) 2005 - 2018, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version 1.41
MEBx Version 0.0.0.0000
GbE Version Unknown
Descriptor Version 1.0
Vendor ID 8086
FW Version 12.0.31.1416 H Consumer
LMS Version Not Available
MEI Driver Version 1904.12.0.1208
PMC FW Version 300.2.11.1020
PCH Information
PCH Version 11
PCH Device ID A305
PCH Step Data B1
PCH SKU Type Production Pre-QS Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x31119140
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Persistent RTC and Memory - PRESENT/ENABLED
Capability Licensing Service Enabled
End of Manufacturing Enable No
Local FWUpdate Enabled
OEM ID 00000000-0000-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Disabled
Intel(R) PTT Supported Yes
Intel(R) PTT initial power-up state Disabled
OEM Tag 0x00
PAVP Supported Yes
Post Manufacturing NVAR Config Enabled Yes
TLS Disabled
FW Type Production
Last ME reset reason Global system reset
BIOS Config Lock Enabled
GbE Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Enabled
Host Read Access to EC Enabled
Host Write Access to EC Enabled
SPI Flash ID 1 EF4018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 5
Trusted Computing Base SVN 1
Re-key needed False
HW Binding Enabled
FPF UEP ME FW
*In Use
Enforcement Policy Not set 0x00 0x00
EK Revoke State Not set Not Revoke Not Revoke
PTT Not set Enabled Enabled
OEM ID Not set 0x00 0x00
OEM Key Manifest Present Not set Not Present Not Present
OEM Platform ID Not set 0x00 0x00
OEM Secure Boot Policy Not set 0x406 0x406
CPU Debugging Not set Disabled Disabled
BSP Initialization Not set Disabled Disabled
Protect BIOS Environment Not set Disabled Disabled
Measured Boot Not set Disabled Disabled
Verified Boot Not set Disabled Disabled
Key Manifest ID Not set 0x00 0x00
Persistent PRTC Backup Power Not set Enabled Enabled
RPMB Migration Done Not set Disabled Disabled
SOC Config Lock Not set Not Done Not Done
SPI Boot Source Not set Enabled Enabled
TXT Supported Not set Disabled Disabled
ACM SVN FPF Not set
BSMM SVN FPF Not set
KM SVN FPF Not set
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
PTT Lockout Override Counter FPF Not set
ME-FW_12.0.31.1416+PMC_300.2.11.1020.rar (1.62 MB)
ME_Region_12.0.31.1416.rar (1.62 MB)
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.31.1416
If someone with more knowledge than me could check the screenshot i made, i would thank him very much.
I have never updated the me firmware on these never devices, and i don’t know if I can do it. Is it safe to do something like this on a laptop? I remember that it was not possible couple of years ago.
Oups sorry, I completely missed your reply. Your system is running NPDM firmware so you need to choose the latest 11.8 Consumer LP NDPM for it.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
D:\Intel CSME System Tools v12 r14\MEInfo>MEInfoWin64
BIOS Version GL703GS.308
GbE Version Unknown
Vendor ID 8086
PCH Information
PCH Version 11
PCH Device ID A30D
PCH Step Data B1
Intel(R) Platform Trust Technology - PRESENT/ENABLED
End of Manufacturing Enable Yes
Intel(R) PTT initial power-up state Enabled
OEM Tag 0x1043
PAVP Supported Yes
TLS Disabled
FW Type Production
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
SPI Flash ID 1 C22018
Slot 1 Board Manufacturer 0x00001043
Re-key needed False
HW Binding Enabled
FPF UEP ME FW
*In Use
Enforcement Policy 0x00 0x00 0x00
EK Revoke State Not Revoke Not Revoke Not Revoke
PTT Enabled Enabled Enabled
OEM ID 0x00 0x00 0x00
OEM Key Manifest Present Not Present Not Present Not Present
OEM Platform ID 0x00 0x00 0x00
OEM Secure Boot Policy 0x00 0x00 0x00
CPU Debugging Enabled Enabled Enabled
BSP Initialization Enabled Enabled Enabled
Protect BIOS Environment Disabled Disabled Disabled
Measured Boot Disabled Disabled Disabled
Verified Boot Disabled Disabled Disabled
Key Manifest ID 0x00 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled Enabled
RPMB Migration Done Disabled Disabled Disabled
SOC Config Lock Done Not Done Done
SPI Boot Source Enabled Enabled Enabled
TXT Supported Disabled Disabled Disabled
ACM SVN FPF 0x00
BSMM SVN FPF 0x00
KM SVN FPF 0x00
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
PTT Lockout Override Counter FPF 0x00
D:\Intel CSME System Tools v12 r14\MEManuf>MEManufWin64 -verbose
Intel (R) MEManuf Version: 12.0.22.1310
LPC Device Id: A30D.
Platform: Cannonlake Platform
Windows OS Version : 10.0
FW Status Register1: 0x94000245
FW Status Register2: 0x02F10506
FW Status Register3: 0x00000020
FW Status Register4: 0x00004000
FW Status Register5: 0x00000000
FW Status Register6: 0x40000000
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
Phase: ROM/Preboot
ME File System Corrupted: No
PhaseStatus: UNKNOWN
FPF and ME Config Status: Committed
FW Capabilities value is 0x31119140
Feature enablement is 0x31119140
Platform type is 0x71000391
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
MFS is not corrupted
PCH SKU Emulation is correct
MEManuf NextReboot option can only run when M3 Autotest is Enabled.
done
Get Intel(R) ME test data command... done
Total of 4 Intel(R) ME test result retrieved
Policy Kernel - Boot Guard : Self Test - Passed
VDM - General : VDM engine - Passed
PAVP - General : Set Edp Port - Passed
Policy Kernel - ME Configuration : PROC_MISSING - Passed
Clear Intel(R) ME test data command... done
MEManuf Operation Passed
D:\Intel CSME System Tools v12 r14\Clock Commander Tool>cctwin gcc
Intel (R) Clock Commander Tool Version: 12.0.22.1310
Copyright (C) 2009 - 2018 Intel Corporation. All rights reserved.
HW Product Family:CNP-H
FW Version Major: 12
FW Version Minor: 0
FW Version Hotfix: 31
FW Version Build: 1416
ICC HW SKU = EXTREME
HECI CMD Status = 0x00000000 (SUCCESS)
Just updated. @plutomaniac can you please see if it's ok?
Everything looks proper, you’re good to go. :wink:
There is the newest version of MEI & Drivers & Software “all-inclusive” package for Intel ME at Station Drivers in 1908.12.0.1231 version that is 300 MB big. However, it requires the previous 1847.12.0.1183 version to install properly.
Quick things I noticed with this version:
- it contains specific ME information for each particular OEM (it installed Gigabyte version for my motherboard)
- it tidily organizes all INF repository packages for Windows 10 (looked up by Driver Store Explorer from GitHub)
- it converts DAL, iCSL and a few other services that were loaded as regular software modules into legit Software Components (looked up with Device Manager)
- it updates system/DLL Intel ME files into the newest versions if applicable (it updated quite a lot of 18XX.XX.XX.XXXX to 19XX.XX.XX.XXXX versions in all of the places)
I tested only the Consumer version, but it seems the Corporate follows the same path judging by their sizes. In my case it didn’t install all 300 MB, but all Intel-related folders grew approx. 52 MB in size.
A question: Do you guys think firmware updates improve performance or similar? I can only think of it getting worse because of security fixes, but not sure.
Probably have this already, but FwUpdLcl.exe and FwUpdLcl64.exe 11.8.65.3572: https://support.lenovo.com/us/en/downloads/DS121676
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.32.1421
Intel MEI Driver v1909.12.0.1237 MEI-Only Installer
Intel MEI v1909.12.0.1237 for Consumer systems Drivers & Software
Intel MEI v1910.12.0.1239 for Corporate systems Drivers & Software
Weird. By default MEI driver should be prioritized by Windows, enabling the “Message Signaled-Based Interrupt (MSI)” option for it, correct?
However, only today I noticed my MEI driver had a pretty high IRQ of 2 in the Device Manager, while my graphic card and system clock had -5 and -6 respectively. Following this guide, I modified Windows registry and voila, my MEI’s IRQ dropped to -7, while my Windows 10 boot time was reduced from 17 secs to 11 (I used BootRacer to measure that, and enabled it for 10 consecutive boots to have a good sample). Just a notion someone might find it useful.
Also, @plutomaniac is LMS a vital part of MEI software? I didn’t have it enabled with the OEM-designed MEI drivers (I mentioned it in the previous post), but it’s now back on with the newest version you posted links to today.
Hi,
I updated to 11.8.60.3561 H and wondering whats the best driver version to pair with this firmware? Seems counter intuitive to go with 11.7 drivers?
Thank you
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.32.1421
@davidm71 If you have windows 8 i would recommend the 11.7 driver, because it works better in my experience.
