The 16.1.30 from Asus for CON H is very new, you should wait because usually not all platforms are getting the same update, it just came out a week ago…
Also a lot of users keep tracking the FW releases whenever they can or come across.
Intel_CSME_ADL-N_16.50.0.1120_A0_Consumer :
Staff Note: The link has been removed to adhere with forum rule 14, regarding “posts or links to documents and/or tools which are marked as Confidential, Restricted, Private, are part of a commercial license etc”. The rule was originally put in place to avoid legal action against the forum and/or the 3rd-party source of the files/info. In this case, the 3rd-party source was evident from the filename as well.
CSME V16.5.0 con system tool:
Hi!
Looking for CSME 16.0 CON LP A v16.0.15.1735 to clear ME ![]()
EDIT: “Any idea how to solve this?” No sry, not my field…
Thanks @MeatWar , but when i rename and replace the decomposed ME Sub Partition.bin with the file from the repo for which you provided the link (intel_me_16.0.15.1735-lp(station-drivers.com)/Non_Capsule\ME_16.0_Cons.bin) I get the following error during building via Intel (R) Modular Flash Image Tool. Version: 16.0.15.1735:
“Exception: Data bucket: ‘OEM_KM’. Error: ‘The public key in the OEM Key Manifest provided does not match the hash provided in CsePlugin:UEP:OemPublicKeyHash’.
Source: ‘CsePlugin:OEM_KM’”
In my case, all I had to do was open this intel ME firmware with MFIT.exe (version 16.0 to be in compliance) and remove the OEM-KM and ISH parts as believe as well (no choice if I removed OEM), and then save and flash this modified firmware (= the same one but without OEM and ISH).
Because ME_16.0_Cons.bin is not ME Sub Partition itself, it’s a prestitched FWUpdate for some Lenovo platform. You have to decompose it first using MFIT, to get unconfigured ME Sub Partition.bin, as you can see on screenshot.
Then you can try to use it for cleaning your initialized bios dump, although it is not recommended to use Extracted type.
@Anton35 Sir you are well deserving my thanks! Spot on with your description. I had no idea that I would need to further decompose the station-drivers provided ME. Thank you very much for your help, i can now see with ME Analyser that “File System State │ Configured” which i assume the correct one.
CSE ME 16.50.0.1232 Production Atom LP Unknown A
PMC 160.50.00.1008 Production Independent Unknown ADP
PCHC 16.50.0.1013 Production Independent ADP
PHY 14.14.508.4007 Production Independent N ADP
v16.50.0.1232.bin.zip (2.1 MB)
hello everyone; i tried to clear a BIOS 64MB of DELL XPS 15 9520 La-l402p, but i got some errors! i don’t know what have to do…
‘’‘ERROR : Decompose ‘C:/Users/Line_teck/Desktop/XPS 15 9520 La-l402p r1.0 Gagarin .BIN’ image failed.
Details: Intel(R) AlderLake P Chipset - Corporate - SPI not found in the available layouts’’
A post was merged into an existing topic: Intel (Converged Security) Management Engine: Drivers, Firmware and Tools (2-15)
How to correct this error? Layout dictionary generated successfully
“ERROR : Failed to initialize MFS.
ERROR : Failed to instantiate container CseRegion:0.1”
when trying to decompress 16.1 image
Heya,
I have came across the following error while I tried to clean the ME:
I receoved a FW image for my laptop for which the bios chip was blown up. I attempted to clean the ME region using MFIT Intel tool of the right version because MEA tool was showing “Initialized” instead of “Configured”. I can decompose the image but unfortunately I am getting the following errors when I try to assemble the image.bin even when I am not touching the ME part (simple decompose and then immediately build):
Start decompose ‘D:/bios/latest badcap/FX517ZM.bin’ image.
MFIT version used to build the image: 16.0.15.1662
WARNING : Skipping ROMB. Missing…
WARNING : Skipping FDCR. Missing…
Decompose ‘D:/bios/latest/FX517ZM.bin’ image completed successfully
Build ‘p:\Gen\HW\BIOS MOD\CSTXE System Tools v16\Modular Flash Image Tool\WIN32\image.bin’ start…
ERROR : Failed to build container: CsePlugin:AutoNvars
ERROR : NVAR ProcEmulation file at path policy/cfgmgr/cfg_rules is readonly…
Source: ‘CsePlugin:AutoNvars’
Would anybody happen to know how to deal with this? Can I try to flash the image even though the bios is “Initialized”?
Many thanks!
CSE ME 16.1.30.2307 Prod ConH ‘Unknown’
PMC 160.2.00.1043 Prod H A ADP
16.302307_1602001043.zip (1.8 MB)
EDIT:
I think this one might be new, too?
Can be found here:
https://fwupd.org/lvfs/devices/com.dell.uefie428af72.firmware
From the PRIME-Z790-A-WIFI-ASUS-1601
MFIT Version 16.1.30.2319
MFIT Core Version 1.1.0
Image Layout Intel(R) RaptorLake S Chipset - Consumer - SPI - A0
Versions:
Important! Versions shown below are applicable to image build time.
In case of FW update for IUP, its version may not be reliable.
ME 16.1.30.2307
PMCP 160.2.0.1043
NPHY 13.62.211.7255
PCHC 16.1.0.1014
SPHY 13.0.1.7085
Available package also @ST
