Intel (CS)ME, (CS)TXE, (CS)SPS, GSC, PMC, PCHC, PHY & OROM Firmware Repositories
Thanks! Either here or for CSME corresponding to version in
:+1: :+1: :ok_hand:
The file you are trying to download is no longer available
What exactly do you need?
I need these files, if you please, thanks!
TGP_150.2.00.1024_H_A_PRD_5FB31D03
TGP_N_15.118.199.0118_PRD_1F96A22F
PMC 150.2.00.1024 Prod Ind HA.bin.zip (87.5 KB)
PHY 15.118.199.0118 Prod Ind N.bin.zip (30.3 KB)
Thank you so much for sharing.
The files in mega were expired,could you upload them on the forum?thanks~
I cannot successfully extract the archive files. Some of the files fails to extract. I used Winrar 7 it still failed.
Point them
CSME 14.0, 14.1 and more in the CS(ME) firmware repository.
Archieve corrupt
Maybe an error during download? 14 abd 14.1 unpack properly with 7-zip?!
Or update your WinRAR.
CSE TXE 4.0.55.2201 B GLK.bin.zip (1.2 MB)
I have this file here! From a Thinkpad X200. It is not in the database.
I see the same version ME in the database. But running CMP i get different results.
Because the files have ALL + AMT but no TPM
The file is: ME 4.1.3.zip - Google Drive (Link because of forum restrictions)
Well, that is a blast from the past, haha. Thanks for the report saberofblack :ok_hand:
3 posts were merged into an existing topic: Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Hello, I share ME CSE Firmware
14.1.53.1649_CON_LP_BA_PRD_EXTR_8ED5E41D.zip (1.8 MB)
I got it from the update installer on the Lenovo manufacturer’s website, and it worked for a computer of another brand.
Why did you name it as RGN ? It is a:
  1. prestitched update with 2 IUPs
  2. extracted, not stock
Hello,
The ME region was extracted from the update file on the manufacturer’s website (Lenovo). Although it shows as extracted, this is because it was configured using the FIT tool and always appears this way.
However, if you look closely, the file system appears as “configured” and not “initialized.” You can see this in the “File System Status” section.
