Intel Integrated Sensor Hub
It is also called Intel ISS, Integrated Sensor Solution.
PCI devices from an inf section:
1
2
3
4
5
6
7
; DisplayName Section DeviceId
%TEE_DeviceDesc%=TEE_DDI, PCI\VEN_8086&DEV_22D8 ;CHT
%TEE_DeviceDesc%=TEE_DDI, PCI\VEN_8086&DEV_9D35 ;SKL
%TEE_DeviceDesc%=TEE_DDI, PCI\VEN_8086&DEV_A135 ;SKL
%TEE_DeviceDesc%=TEE_DDI, PCI\VEN_8086&DEV_5AA2 ;BXT-P
I have three seperate drivers, ISH miniport, ISH busdriver and the ISH driver with the PCI ids. For it to work with windows 7 you seem to need a few files in directories called AdvSensorHIDClassDriver and Win7SensorHIDClassDriver, which seems logical, because Win7 is missing something for those sensors.
I have a current version 3.1.0.3363, that does not work with win7 and an older version 3.0.41.3260 which does work.
Anyway, can we get a topic where Fernando is mentioning all the new driver versions of this thing? :-D
@jjurkus :
Attached are the Intel ISH drivers v3.1.0.3360 dated 08/11/2016, which should support all Windows Operating Systems from Win7 up.
Why should I do that? Intel’s ISH drivers do not belong to the "Storage Drivers", which is one of our main topics.
Good luck!
Intel_ISH-Drivers_v3.1.0.3360_for-Win7-10.rar (1.17 MB)
Oh, I thought this was for all other hard to find drivers. I keep forgetting the Intel ME stuff is a special topic and not covered in this part of the forum.
And this site is way better than hoping to find it on the intel site. Thanks for that
