Same problem with MSI GT62VR 6RD , msi released same tool (from intel i think) for my laptop , after applying that patch my laptop is unable to shutdown and reboot properly (need to keep power button pressed to shutdown), also booting takes a while (stays around 1/2 mins on msi logo , trying to load bios i suppose). Tried everything for now , also reflashing same (latest) bios version , reflashing EC fw , reflashing ME fw but intel tool returns errors…
My laptop starts really slow too. Your issue seems almost same as mine.
Now, I am trying to dump my bios image… but it also prints error message
The host CPU does not have read access to the target flash area. To enable read access for this operation you must modify the descriptor settings to give host access to this region.
I tried FPT too but nothing… BIOS region is accessible but ME region is locked…
As i said i can flash BIOS using AFUWIN , just BIOS region , nothing to do with ME FW.
The problem is that also if MSI (in my case) releases a new bios update i can’t flash FROM BIOS (from bios should flash ME region also) because when i select my BIOS ROM from usb , then laptop needs to reboot to flash and here’s the problem because my laptop actually can’t reboot/shutdown himself…
If i keep pressed power button to turn it off and then i turn it on , BIOS returns an error saying something like there was an error and BIOS can’t be updated
We need @plutomaniac help with his ME fw experience , if there’s something we can do
You’ve already tried setup_var which modification is not strange to be locked out by the OEM for security reasons. Have you tried the audio chip pin shorting for temporary allowing CSME firmware region read/write access? For Realtek audio chips, the instructions can be found here (example picture). For HP, there might be some hidden hotkeys that they use at the factory to quickly unlock the CSME firmware region for servicing. Try holding Right Arrow & Left Arrow and press the Power Button when the system is fully shutdown (S5 state). Maybe it’ll work, otherwise you may be able to find something else by looking online.
