Intel Nuc 8i5BEB-need help
The relevant parts of your dump look OK.
That’s the file you used from the forum and the marked parts are the regions and entries you have to replace with the corresponding parts of your dump.
Your own dump with the parts you need to transfer marked:
  • GbE is from 0x1000 to 0x3000 (your GbE has it’s MAC address at 0x2000 (adress for the complete file, 0x1000 for the region)
  • The entries in NVRAM are from 0x800090 to 0x800348 (adresses for the complete file)
The new file reco.rom should look absolutely identical in UEFIToolNE after the exchanges.
Post the file again when ready if you wish for a check.
Hello @lfb6,
I’ve reflashed again the chip and now I have the System Information corresponding to the box sticker data (SN, Version), but the “Board information” doesn’t repeat the same values.
Do you know if it is normal?
I attach a screenshot.
Expected- see your own dump. Machine serial ≠ board serial
Hello @lfb6,
Thank you a lot.
Indeed, it is clear from the dump.
I think we can close this topic.
KR,
Alexander.
