Intel USB EHCI Switcher tool
Hi all,
I’d like to present my tool that allows to switch USB 2.0 ports to EHCI controller on Intel 7, 8 and 9 series and x99 chipsets.
As you probably know xHCI controllers have much lower device count limits compared to EHCI controllers. This, combined with fact that on Intel systems all USB ports are handled by xHCI controller causes issues for users with lots of USB devices. Official solutions are “disable USB 3.0” and “buy expansion card”. However, turned out that this Intel platforms have 2 EHCI controllers that are simply not used. Studying Intel datasheets revealed that all three controllers can be used if xHCI is configured as “Smart Auto” in BIOS.
What is interesting - even complex cases like composite USB 3.0 device containing both 3.0 and 2.0 devices are handled correctly - 3.0 devices are connected to xHCI and 2.0 are connected to second EHCI controller.
Link to GitHub: https://github.com/Alexx999/IntelUsbSwitcher
man, ur tool has helped me a lot.
my platform is the old school X99.
recently, I’ve been struggling with a popping noise issue to a new USB DAC based on XMOS.
I’m not newbie, to eliminate the noise I’ve tried every possible solution I could think of or find online.
system, driver, firmware, overclock, dpc latency, power setting, HPET and clock…
but nothing help, until I found your topic.
switch the USB DAC from XHCI to EHCI, the nosie is gone, cheers!
Glad to hear it actually helped someone :slight_smile:
