Is it possible to enable iGPU via UEFI scripting on intel C246 based system?
Hello,
I have a request that I’m pretty sure is impossible due to Dell’s configuration. I have a Dell T340 with an E-2176G processor that I originally purchased with hopes to use QuickSync. Dell has disabled the iGPU due to their IPMI configuration.
I had given up hope until noticing that the ASRock E3C246D2I does have a method to enable the iGPU.
I’m new to this topic, and I was wondering if there was anyway to configure support for this using the UEFI shell to set the variables required directly?
Thanks!
HI, Hello,
I have the same problem with dell T340 nvidia RTX 3080 is not recognized by the almalinux system. I have a small LLM.CUDA project; I wanted to use the GPU for this purpose and keep the display with the matrox of the motherboard. lspci does not display the gpu card references; do you have a return from dell or some solution to get out of it!
perharps using shell UEFI !
Thanks in advance for your request.
Regards
Henri
