Lenovo Legion 7 AMD raid help
82N600DUUS 16ACHg6. I tried the bios unlocker and enable nvme raid but there is no place to configure the drives in a raid. I have the H20UVE uefi variable editor gui but the variable that says AMD raid is all 0’s atleast when I dump the bios with H20UVE.
You need to "Intel(R) Rapid Storage Technology" menu there you can create and manage RAID volume. Unfortunately, unlocker does not give access to it.
So, is there a way to set “Intel(R) Rapid Storage Technology” menu up in the BIOS?
It depends on what your device is.
An AMD-based laptop: Legion 7-16ACHg6 82N600DQUS
AMD-based require a SPI programmer tool.
Thanks for the reply, Sweet_Kitten, appreciate it! And yeah, that’s further than I want to go.
