I have a motherboar from MSI
- Motherboard Manufacturer: MSI
- Model: P55-GD85
With a Marvell Chip 88SE9128.
I had to update this chip with a new firmware
I choose this firmware: Bios pour MV-91xx Version 2.2.0.1125b
In the first step i had i making a dos usb stick with these data "mvf_mag" and "image"
With these parameter "mvf_mag.exe image GO -b -b" i had flash the chip.
The programm goes running and its done.
Now i have a marvel 91A3 chip. That is not good
By booting it isnt coming the marvel controler now after the bios.
In the second step i had it to flash again with a new dos usb stick.
In the root is "GO.BAT" and the folder „bin“
And in the folder „bin“ is "image" "mvf_mag.exe" "MVM.BAT" "spi_info.txt"
And now i flash the chip with theese parameters:
„GO -b –v“ the firmware
„GO -a –v“ the autoloader
91A3 stay again
In the thierd step i crash all
Now i flash the BIOS from my motherboard.
And now the marvel chip are now 9128.
But he is in the driver control panel from windows.
When i try to do the second step.
The flash program didnt flash the chip its came the massage
„Flash error, wipeout autoload!!“
And then
„failed signature#
Flash Failed!!“
Pls help me
Sry for my bad english
@ XerXes777:
Welcome at Win-RAID Forum!
Since I am not an expert in the reparation of a failed Firmware update, I cannot help you myself, but I am pretty sure, that you will get support by other Forum members.
Regards
Fernando
@XerXes777
Your first step should have been “go -r” to backup current firmware.
Try to flash SP1813 from this post. Use only “go” or “go -y” or “go -y -v”. The first command you used had no sense, while “go -b” will flash only OROM/BIOS, not the firmware.
If this doesn’t work, you only solution is to use a programmer to flash a 512KB image. But post back anyway, maybe there will be something else to do.
