Good morning everyone,
I have an ASRock z77 oc formula, unfortunately I briked the ME losing some overclocking options (adjust cpu frequency) in the BIOS and two ram slots are no longer recognized by Windows. I’m trying to overwrote the BIOS chip with a programmer but I don’t know what image I have to flash. Can someone help me?
You need the "Instant Flash" package. That should contain the full flash content.
@Deam96 - FIRST!!! Dump your BIOS! Or you will loose your LAN MAC ID (Ethernet) then send to me, I will make you BIOS to program in.
Thank you so much, I will dump the bios and I’ll probably send it to you tonight
Hi guys.
I’ve dumped both the chips. Than a friend suggested to boot from the second chip and than try flashing the first chip from that.
After the flash all the options are back available.
Thanks for the help, if you’re interested I can upload both binaries.
@Deam96 - Hey! Yes, sorry, I didn’t realize you had two chips here or I would have suggested the same! Now, update to latest BIOS again and you’ll be all set and good to go!
Thanks for the help all work flawless.
