Hello, I have a really big issue. For last two days I was trying to repair MacBook Air 2014 for my friend, later I found out that issue is with bios.
I had flashed bios from another MacBook but I cannot find working ME Region. Does anybody have one? Firmware version is 9.5.3.1526.
Could anybody help with it? Thanks in advance.
Thank you for your answer. But I cannot find ME 9.5.3.1526.
At step 4 you’ll need to pick the same or newer SLM EXTR firmware since we don’t have RGN for Apple systems.
ok thank you
No raw file but it is like raw file already. The region is reset to stock. You need to clean the region.
9.5.3.1526_1.5MB.bin.zip (584 KB)
@depeyrace ^^
