ME scrambled ?
Since i’m new here, first of all: hello to everyone ! - I will appreciate your help.
The main problem is a non working nic in a HP 8300 USDT.
The configuration menu item for the nic, within the Bios is gone as well.
So might be a defective nic, or a corrupted bios/firmware ? - Is there an easy way to sort that out ?
It seems things like missing nics could happen, when flashing from very old, to latest bios, leaving out intermediate updates.
I first tried to downgrade to earlier bios-versions - without luck. There is a BBR-jumper on the mainboard, but it seems not to have the desired/described funktion.
So went on with ME-firmware (FDO-jumper works) as described here:
*****://h30434.www3.hp.com/t5/Business-PCs-Workstations-and-Point-of-Sale-Systems/Intel-Network-Card-and-Management-Engine-fail-to-initialize/td-p/6976862
(replace ***** with https - newbies can not attach links ?)
This led me to a disabled ME, and a still missing nic-configuration option.
The current ME-info output:
Intel(R) MEInfo Version: 8.1.56.1541
Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E040195
FW Status Register2: 0x1652010A
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: Bring Up
InitComplete: Initializing
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Unsecured mode by H/W jumper
ICC: No valid OEM data, ICC programmed with default values
PhaseStatus: UNKNOWN
HECI device is found to be disabled.
SMBIOS Table Data
SM BIOS Spec Version : 2.7
Starting address: 0x E87C8
Table Size in Bytes: 2130 ( 0x852 )
Number of Table Entries: the 51 ( 0x33 )
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
SMBIOS Table Data
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 22 (0x 16 ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 16 ( 0x 10 ) found, size of 23 (0x 17 ) bytes
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 24 ( 0x 18 ) found, size of 5 (0x 05 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 41 ( 0x 29 ) found, size of 11 (0x 0B ) bytes
Table Type 17 ( 0x 11 ) found, size of 34 (0x 22 ) bytes
Table Type 20 ( 0x 14 ) found, size of 35 (0x 23 ) bytes
Table Type 4 ( 0x 04 ) found, size of 42 (0x 2A ) bytes
Table Type 19 ( 0x 13 ) found, size of 31 (0x 1F ) bytes
Table Type 13 ( 0x 0D ) found, size of 22 (0x 16 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 127 ( 0x 7F ) found, size of 4 (0x 04 ) bytes
Error 9458: Communication error between application and Intel(R) ME module (FW Update client)
Error 9459: Internal error (Could not determine FW features information)
So beside the still active ManufacturingMode, there is specific oem data missing ?
The extracted ME-region from MEInject had just 7599KB - smaller than expected by fpt.
I have a second PC, same make/model which is working fine. It may be used as a donor ?
I could even flash the whole bios dump from one to the other, but have no idea how to keep the individual data then. ( mac, serial … )
If you need more input, let me know …
