MECHREVO X1 Series GJ5KN6A
Hi, I want to mod the bios on my MECHREVO laptop, but I don’t think that the bios for this one has been dumped, and the bios mods for the other MECHREVO laptops have different names…
The specs for my laptop are:
i7-7700HQ
GTX 1060
Bios version N.1.05 (AMI)
How would I unlock my bios?
@tsmswifty - I will do it for you and add that model to the main guide, and I’ll use your dump from the guide thread for your actual mod BIOS I send to you.
Please link me to the stock BIOS download from manufacturer, or at least stock untouched BIOS install package, with all originally included content for the BIOS only, don’t include all other drivers (Some manufacturer links is 10GB)
I can’t find that; the manufacturer never released any. My laptop is the Mechrevo X1 with i7-7700HQ + GTX 1060 config
OK, I will try to find, it’s not necessary for the mod, I just wanted in case anyone needs stock version N.1.05 before they can do the mod for this system. I see from Google N.1.06 BIOS is out there too.
Let me dig around and see if I can find stock BIOS packages for both, and then I’ll do the mod for you and add this model to the guide files.
http://www.mechrevo.com/plus/search.php?..peid=25&exact=1
This is the link for the drivers for this model of laptop; unfortunately no BIOS. I’ll see if I can use google translate and communicate with them, but I doubt they have it…
Thanks, I appreciate it!
You’re welcome! This is “Deep Sea Titan” Series, does it have a model on the bottom anywhere, that looks similar to any of the ones in the dropout for that series here
http://www.mechrevo.com/en/html/fuwuzhic…azai/index.html
@tsmswifty - here is your mod BIOS region, flash back via >> FPTw.exe -bios -f ddpce8M.bin
http://s000.tinyupload.com/index.php?fil…071513727080929
Guide will be updated shortly with this model added to the list, thanks for brining it into the threads attention
You have to switch to the chinese site to see it apparently
So, this one then, correct? http://www.mechrevo.com/html/shenhaitait…7/0809/194.html
Where do you go for drivers/BIOS there, I can’t find it?
http://www.mechrevo.com/html/fuwuzhichi/…azai/index.html ← here
I don’t speak chinese but google translate is a miracle
update: it works, thanks so much!
Thanks, I tried translating with Bing I think, didn’t help, should have used google. Your link above takes me to Chinese “pick your model”, so not ideal either?
Can you link me directly to your model driver/BIOS download page? * Edit, never mind, I got it, but not with google’s help, that spit out 404 page after picking a model.
It’s Here - and no BIOS
Glad the BIOS is working for you, I knew it would, thanks for quick report back!
