For awhile now I have been hoping that a patch would come out to deal with the Spectre exploit for my processor. After close to 4 months it’s becoming clear that I might not be-able to patch it using the microcode updates on Intel’s site, or a bio’s update for my motherboard, an Asus X79 Sabertooth. I’m still using Windows 7 SP1 and I would like to stay there if possible.
I see one or two people here have been able to patch the exploit for 3930k, I’ve also been reading the other threads and i’m not 100% sure where I should start, or even what safety precautions I should take before hand.
Hi, Here the latest Asus X79 Sabertooth (https://www.asus.com/fr/Motherboards/SAB…pDesk_Download/), the latest stable bios is version 4701. Be sure that it’s the right motherboard model. So i modded this bios with latest compatible firmware and latest microcodes against Spectre. USE IT AT YOUR OWN RISK!!! https://www.mediafire.com/file/cib4bslnk…ASUS+MOD+X79.7z CRC32: BB04DFCA MD5: ED5FA2C3EE776DD4BC954C80E5099E5B SHA-1: 4483085D45EB7D576C30DE28435C7974176EDFA5
Look’s like i’m making some progress. Once I get figured out how to rollback my bio’s to the point where I can start using bin structures again and not cap I should be home free to use the modded bio’s. Disregard that, i’m a idiot.
Ok, so I rename “ASUS MOD X79.bin” to “ASUS MOD X79.rom” and then use “BRenamerl” to make the file into a valid cap file, correct?
@Walls Sorry about the follow up delay, I was out of town for a bit. I was able to get the system to read it as a cap file but now I’m getting “Security Verification Failed”. What I did was use the beta bio’s 4801, and then the spectre patched microcode to make the cap file readable.
@mbk1969 I am not moving to Windows 10 under any circumstances.
@jaken As you wish. I am on Win10 since 1607 and have no issues with my x79 rig. And with latest KB with microcodes I don`t need to bother with BIOS modding to utilize newest microcode.
As I take it you have ASUS motherboard. Use USB flashback feature to flash modded BIOS.
@jaken Too bad that you’ve this error message when you try to flash modded bios (maybe ram compatibility or something else), be careful with beta bios it’s a huge risk!!!
@mbk1969 I also run a x79 mobo with windows 10 without any issue, i guess jaken use Windows 7 or 8.1 and i think it’s good for him.
If bad checksum then don’t flash it, need a new BIOS mod. If you guys need a modification that should flash without bad checksum issue mod with MMTool and insert new microcodes manually, UBU should fix checksum issues but maybe there is a bug.
No matter what, BIOS would still need to be flashed with one of the methods in the above link I posted
