Modded Intel AHCI and RAID Drivers (digitally signed)
Hello Fernando , I have an ASRock Fatal1ty P67 Professional motherboard and I want to install windows 2000-winxp 64-bit and Windows 764bit. I have downloaded these drivers Generic 64bit Intel RST AHCI driver v11.2.0.1006 mod+signed by Fernando and tried to load them by using a floppy and F6 at the start of the installation but I always get a blue screen . SATA/AHCI is chosen in bios . Cn you help me solve this ?
@moumiaq
Welcome to the Win-Raid Forum!
The Windows Setup only accepts WHQL certified and no modded textmode drivers.
So you have to load or to integrate an original driver, which has been digitally signed by Microsoft. Once the OS hasbeen installed, you can change the in-use WHQL certified by a modded one (after having installed the related signature Certificate).
Post:
I recently ran into an issue when preparing a Windows 10 USB for installation on a system, that needed AHCI/RAID drivers with Win-RAID certificate, with no image or option to first install Win-RAID cert
Problem
  1. Some Windows 10 ISO install.wim files exceed 4GB and cannot be copied to a FAT32 USB (required for UEFI boot).
  2. AHCI/RAID drivers fail to install during setup unless the Win-RAID CA certificate is present.
Solution Steps
1. Split the oversized WIM file
Open PowerShell as Administrator. Create a temporary folder for split WIM files:
mkdir C:\ISOTemp
Split the WIM into smaller SWM files (~3.8GB each):
Dism /Split-Image /ImageFile:D:\sources\install.wim /SWMFile:C:\ISOTemp\install.swm /FileSize:3800
2. Prepare the USB
  • Format the USB as FAT32 for UEFI boot.
  • Copy all Windows installation files to the USB:
robocopy "C:\Users\YourUser\Downloads\Windows_10_20H2.3" "D:\" /E /COPYALL /R:2 /W:2
  • Replace the original install.wim with the split SWM files:
Copy-Item C:\ISOTemp\*.swm D:\sources\
3. Inject Win-RAID CA Certificate
Copy the certificate into the mounted offline Windows image:
copy "D:\Win-RAID CA Certificate\Win-RAID CA.cer" "C:\Mount\Windows\System32\Win-RAID CA.cer"
Load the offline registry hive and add the certificate:
reg load HKLM\Offline "C:\Mount\Windows\System32\config\SOFTWARE"
certutil -addstore -f -enterprise -user "Root" "C:\Mount\Windows\System32\Win-RAID CA.cer"
reg unload HKLM\Offline
4. Inject AHCI/RAID Drivers
Add the drivers to the offline image using DISM:
dism /Image:C:\Mount /Add-Driver /Driver:"D:\Drivers\AHCI\x64" /Recurse
5. Unmount the image
Commit the changes and unmount:
dism /Unmount-Wim /MountDir:C:\Mount /Commit
6. Boot Your USB
  • The USB is now FAT32, UEFI-bootable, and includes the necessary drivers and certificate.
  • Windows setup will correctly recognize AHCI/RAID hardware
Thank you very much Fernando
