Modded USB Drivers Depot 2000 XP 2003 2009
INTRO:
XP Modded USB Drivers Depot for future collection of all modded USB drivers in one location.
You want more ram on XP ?? Try my patch here https://ryanvm.net/forum/viewtopic.php?f=7&t=10547
Want usb 3.0 port from intel work ? Then put Rensas usb driver with inf mod
can you provide device id of your hd gfx ? I have got it work under Z170 A from Asus
can i also have your INTEL Gigabit Ethernet controller device id?
The best PAE patch - fix128
https://rutracker.org/forum/viewtopic.php?t=4694409
I have used XP64G 2.1 Beta(mentioned by dibya in the link below)on AMD A88X with 4GB ram, no pagefile and a 1GB grahphics card, combined with a Maniac Barebone Services registry file. XP Pro SP3 can run with only 4, Four, services running.
I need to work USB under XP.
My motherboard - H110, USB 3.0 Intel - PCI\VEN_8086&DEV_A12F
Which Renesas driver should I modify?
8-8-2019
Blu-ray Playback Performance on Intel Coffee Lake CPU
CPU:
Intel i5-8400 Hexacore
Video:
nVidia GT 710 PCIe
Audio:
Generic USB Audio output
Graphics Driver:
Experimental Compact Purity Driver
[Minimum Best Underclock CPU Settings for Smooth Playback]
#1
6 Cores disabled to use only 2 Cores
Optimal Clock Speed:
1400 MHz (1200 MHz reaches almost acceptable levels)
CPU utilization:
64%-100%
CPU Core Auto Voltage:
0.720V-0.732V
CPU Temp:
28.0 C
#2
Overkill
6 Cores disabled to use only 3 Cores
900 MHz
CPU utilization:
60%-100%
0.660V
0.672V
CPU Temp:
28.0 C
#3
Overkill
6 Cores disabled to use only 4 Cores
800 MHz
CPU utilization:
67%-85%
0.648V
CPU Temp:
27.0 C
#4
Overkill
6 Cores disabled to use only 5 Cores
800 MHz
CPU utilization:
48%-74%
0.648V
CPU Temp:
28.0 C
#5
Overkill
All 6 Cores Enabled
800 MHz
CPU utilization:
31%-52%
0.648V
0.660V
CPU Temp:
28.0 C
Where USB drivers?
