Hi there,
I having been trying to get my system to work but constantly getting BSOD’s and having alot of issues with the USB 3.0 drivers causing system crashes.
I am not sure if the 3.0 driver crashes from bad pool header are just an issue with the drivers as I can see info saying ntkrnl file and ntfs.sys as files with problems. Not sure if these will be resolved once I get the driver stuff sorted.
Need to know exactly what I need to install on my Windows 7 Ultimate system, using Ryzen 3200g and a B450M Steel Legend Motherboard.
Do I just use all the files here - Solution-Win-Drivers-for-USB-Controllers-of-new-AMD-Chipset-Systems.html Not sure as I see talk about AMD 500 boards.
Can someone please tell me exactly what I need this is driving me utterly crazy. I can’t pm the guy who made the post about AMD chipsets either.
300/400 series M.B. can use <Solution-Win-Drivers-for-USB-Controllers-of-new-AMD-Chipset-Systems> too.
The latest version Official USB Driver has bug, <Solution-Win-Drivers-for-USB-Controllers-of-new-AMD-Chipset-Systems> used older version to replac that.
「The driver package already contains all the supporting drivers of AMD, so there is no need to install the AMD CHIPSET DRIVER.
Because its 2.0.0.48 USB driver of the official driver will cause the system 0x000000C2:BAD_POOL_CALLER BSOD.」
Thank you for confirming am using those drivers and system seems to be working and stable so far.
