Hi! First of all english is not my mother language, sometimes using translate apps, sorry for any mistypo.
I have Z370 AORUS Gaming 7 motherboard. Need to enable SPD Write but there is no option visible in bios.
When ı try to open bios with AMIBCP5 it says:
Maximum number of strings per section exceeded. Setup Configuration and BIOS String tabs will not be shown.
When ı try it with AMIBCP4 it opens but lots of setup configurations says undefined and ı dont know what they are.
When ı search spd word in bios strings SPD Write Disable string is there but ı dont know hot to edit it.
I try to use uefıtool. Shows security protect. AMI v2 protected ranges hash file found at base 00FC18F0h.
Only view options enable, ı can not change anything.
Here is my bios file: Z370AOG7.F15 - Google Drive
