it8252e248a ? you need change manualy what size is chip to 248kb
Yeah mb its it8252e248a, I forgot about 2. I might try that but its weird that it even started with 128kb
https://youtu.be/astOCno-S3U?si=KYTrblmjOKWsfGWS content can be interesting for you, first comment even more.
I quote "During the first KBC cleaning, I had the wrong memory configuration set, i.e. 128kB (default for SVOD regardless of the detection of the EC model), later I tried the 256kB configuration."
248kb works only without DMI aswell so I guess there is nothing else to try, it seems like there is some kind of software issues, no matter how many options i tried like 20-30 laptop will boot only without DMI and only with original bios, any bios from other laptop will not work
What does that exactly mean? Original bios is stock bios or your own ‘original’ bios? Boot means boots into an OS?
I mean my own original bios and yeah it just can boot to OS without any problems but only with dmi deleted. Even with my original dmi laptop dont wanna boot anymore, its hard to find why for now I guess that just asus loves to complicate things. It looks like for some reason every laptop has his own bios that will not work on any other asus laptop at least in this model.
edit: Even erasing KBC didnt helped and laptop still was able to boot only without DMI
OK, thanks. And what precisely do you mean by ‘dmi deleted’?
(I don’t think this is Asus, it’s AMD and probably AMD software TPM)
By that I mean bios without S/N, windows serial and stuff like that
I saw this program can do great work with broken BIOS
https://www.kocham-basie.pl/program-ubt2-p-1500.html
I actually used this program and he fixed broken bios but it works only without dmi so s/n, and rest of serial numbers. Bios with dmi will not boot no matter of what
Yes, that is clear, but how / where.
Would you mind posting the firmware which boots ‘without dmi’?
