Hi Everyone,
in desperate need for help here - I’m another fool who has bricked his system through CPU undervolting via XTU.
Long story short I was trying to reset my XTU undervolt values to default and in my tired state I think I clicked the wrong thing and after restarting; the laptop no longer posts.
Initially the keyboard backlight would turn on, fan spin but no post. After a CMOS reset / battery pull the keyboard backlight no longer turns on but still get fan spin / no post.
I modified a CH341A to run on 3.3V and used a guide on this forum to read the only chip on the motherboard which looked like the BIOS chip (25B127DSIG). There are other components on the board which i suspect are the VBIOS and another 3 components that I believe are MOSFETS when I google them …so I am fairly sure I have the right BIOS chip…
I was trying to dump the Bios and re-flash it with the stock Bios from Gateway (Version N1.02). The problem I have is that the bios dump using both ASprogrammer and CH341A Programmer both crate a 16mb BIN file whereas the bios files I have from Gateway is only a 13mb ROM file.
When I did flash the 13mb ROM file I get no power at all from the system - No fan spin, no post. But when I flash back to the original bios, I go back to Fan spin - No Post.
Not really sure what to do from here. I have the original bios BIN file and will try to upload if anyone can read it and confirm this is the BIOS. Any help is greatly appreciated.
EDIT 1: Link to my 16mb dumped Bios: Original Bios.rar - Google Drive
EDIT 2: Link to 13mb Bios i am trying to flash: GKxMP60xN102.ROM - Google Drive
EDIT: Cant upload my BIOS as a new user - Will try and upload it elsewhere and link.
25b127 - is your BIOS. How to fix it? You should extract the corrupted files, keeping the me area. And merge the good BIOS area and me area to complete the repair.
This sounds like i am on the right path but not sure i fully understand how to do that.
Could you point me in the direction of how i would merge the good Bios and ME area please?
Using UEFItool replacement is the easiest way.
Have just downloaded UEFItool but admit i do not have the skills to do this. Any guide I can follow or any kind soul who would be able to do this for me?
The 16mb file doesn’t look like the backup is complete. Try it. Maybe with luck.
IT WORKED!!! IT ABSOLUTELY WORKED!!! I have been struggling with this and reading every corner of the internet that i could for a week now! Thank you so much!
First off all, lesson learned DO NOT change the graphics mode on this computer. Husband set it to “DGPU only” and caused himself a good hour of frustration/panic.
Just in case anyone else runs into this problem, or similar, no display but powers on… My husband found a way to reset the bios to default without seeing the screen.
1: Fully shut down computer
2: Press power button, tap DEL/F11/whatever your bios key is for about 15 seconds, until you would normally see bios displayed.
3: press "F3>Enter, then press F4>Enter
Laptop rebooted right to Gateway splash screen, then into Windows. working normal now
Can I ask you to send me this file. This link was expired, unfortunately. I appreciate it
Hello,
@553349149
Can I ask you to send me this file to. This link was expired, unfortunately. I appreciate it
Thank you.
Hi. Can you share the file?
