Hi, I’ve a Ryzen 5800x3D that don’t have Curve Optimizer in bios.
I know and use about PBO2 tuner.
But I read that if you load a saved profile from another ryzen 5xxx you can get it at bios frist time you load, and then you can modify the curve optimizer at bios.
I loaded a saved profile from my previus Ryzen 3700x and I get almost hidden functions like CPU Voltage that is working fine if you modify it. But my old Ryzen 3700x don’t have Curve optimizer.
This is why I need someone that share with me a optimized defaults saved profile from a ryzen 5xxx from a Gigabyte x570s ud with f4d Bios or a Bios Mod that unlocks all features in a Ryzen 5800x3D.
Link to the Bios: https://download.gigabyte.com/FileList/BIOS/mb_bios_x570s-ud_f4d.zip?v=c640232136b51d23c8d5c48e4c32e478
Thanks in advance for your help.
Cheers.
