Hello guys.
I am trying to modify the BIOS on the Razer Blade 13 RZ09-03102 (version 1.04).
With the CH341A programmer I was able to get a clean dump, which I then proceed to modify with AMIBCP (v5.02.0034) following this guide: GitHub - stonevil/Razer_Blade_Advanced_early_2019_Hackintosh: Razer Blade Advanced early 2019 Hackintosh. Guide and EFI
I was able to flash the modified BIOS with the CH341A programmer correctly and was even able to change values on the Main tab such as BIOS version, etc.
However the options that I unlocked by setting USER as access value are not showing up and I do not understand why.
Here you can find a copy of the original BIOS and the one that I modified: BIOS – Google Drive
If anyone had similar experiences or know a better solution to modify the BIOS file please let me know.
