Need HELP
hiiiiiiiiiii
Dear director
I want to change the information BIOS
Will the factory serial number change?
Will other BIOS specifications change?
I want to change all the specifications in the computeres
i have optiplex 7010 dell
please help
388/5000
I have tried the methods available on the Internet
But I have not received an answer
The computeres in the BIOS are disabled
How do I edit service tag and adress mac?
I’ve already used the file edit ram method
I found the service tag in the file
I want to change it but I do not know how?
Can I get another ROM from another place to flash it on my BIOS?
What method should I use?
plz help
I’ve answered you twice about this in PM’s, and sent you tools to do the edit with Dell tool too.
Is MAC Working now? if yes, you cannot change it, unless you reprogram the LAN CHIP FW too (not ideal, unless it’s one system)
Serial, Asset, and Service tag can all easily be changed any time by using the Dell tools I sent you.
No, do not flash some other rom into your boards, then you will have those systems incorrect ID info.
@Lost_N_BIOS :
thank youuuuuuuuuuuuuuuuuu
my bro
I’m doing the way you gave me
I’ll report to you
thank you again
Hi @Lost_N_BIOS, can you send me the same tool? Will it work for dell precision t3610?
And do i have to edit my already modded bios again?
@thorne
Don’t expect a reply. Lost_N_BIOS hasn’t been online since a very long time.
Thanks @Fernando
