...need to make strange bios for strange motherboard little bit less strange.
Hi.
I have an X89-L motherboard from aliexpress. It is a chiniese board with G34 socket and 2 DDR3 slots. It is actually not an uATX (25.5cm, not 24.4) and it have a very funny AMI based BIOS. It was edited/created not very carefully and it includes a lot of unnecessary options, like a settings of IDE port, or selection of primary graphics card. Can anybody look at it? There are 2 files in archive. ORIG - saved my me from mobo, NEW - sended by seller. Versions are the same, but checksumms are different.
https://cloud.ideafix.co/index.php/s/E0dZyBGQnrIBs4e - link to the zip archive.
https://aliexpress.ru/item/1005001370713428.html - board overview
P.S. It is working fine with Opteron 6276 and 6378 (no stress testing!) and 2x16GB of PC3L ECC RDIMMS. And it is possible to find used SuperMicro H8SGL/H8SGL-F for the same money, but JingSha is more funny than Supermicro, IMHO :slight_smile:
Ami bios 3
acpi aml module: says windows 2001 sp1
pci 1002:4392 module: amd raid array v3.015
pci 8086:10e7 module: intel boot agent GE v1.3.53 PXE
pci 1a03:2000 module: aspeed graphics vbios v0.93.08
ASPEED support has graphic drivers and bios files
Bios looks good.i cant comment on board’s build quality though
please add screenshots from bios.insert an usb and press F12,should do the trick
